Salta al contenuto principale
Introduzione
This is a quick guide on how to replace the charging port of a Toshiba Satellite E45t-B4204. Replacing the charging port can fix a charging port due to excessive use.
Parti
Nessuna parte specificata.
  1. Remove all 14 of the 4 mm screws on the back side of  the laptop with a Phillips #1 screwdriver. Remove all 14 of the 4 mm screws on the back side of  the laptop with a Phillips #1 screwdriver. Remove all 14 of the 4 mm screws on the back side of  the laptop with a Phillips #1 screwdriver.
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Gently pull out the battery. Gently pull out the battery.
    • Gently pull out the battery.
  3. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
  4. Lift up in the spaces left by the battery to create a gap between the back case and the laptop body. Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on. Remove the back case.
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  5. Locate the charging port housing.
    • Locate the charging port housing.
  6. Unplug the charging plug housing from the motherboard. Unplug the charging plug housing from the motherboard. Unplug the charging plug housing from the motherboard.
    • Unplug the charging plug housing from the motherboard.
Conclusione
You didn’t complete the instructions. It ended after you said unplug the charging port housing. The pictures are not clear. Please add red lines or arrows, etc. to show what you are trying to do. It doesn’t show or spell out the next steps to replace it.
Correy Smith Hartzog - REALTOR - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 30
Ultimi 30 Giorni: 139
Tutti i Tempi: 441
