Salta al contenuto principale
Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement
Cosa ti serve
  1. Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement, Battery Replacement: passo 1, immagine 1 di 1
    • Remove the fourteen 3.75mm screws with a Phillips #0 Screwdriver as shown.
  2. Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement: passo 2, immagine 1 di 1
    • Gently pull out the battery.
  3. Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement, USB Port Circuit Board: passo 3, immagine 1 di 3 Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement, USB Port Circuit Board: passo 3, immagine 2 di 3 Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement, USB Port Circuit Board: passo 3, immagine 3 di 3
    • Using a spudger, poke the white tabs in by the battery until you hear a click.
    • Separate the laptop by sliding a spudger in between the black and silver covers.
    • Be sure to use ESD-safe tools, we recommend the iFixit toolkit.
  4. Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement: passo 4, immagine 1 di 1
    • Using the #0 Phillips Head, unscrew the two 3.75mm screws connecting the USB Port Circuit Board to the hard drive and remove the USB Port Circuit Board as shown.
Conclusione
Tori Ryals
Membro da: 10/11/16
41 Reputazione
2 Guide realizzate
USF Tampa, Team 1-4, Leahy Fall 2016 Membro di USF Tampa, Team 1-4, Leahy Fall 2016
USFT-LEAHY-F16S1G4
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 431
