Salta al contenuto principale
Toshiba Satellite E45-B4100 Cooling Fan Replacement
Cosa ti serve
  1. Toshiba Satellite E45-B4100 Cooling Fan Replacement, Battery Replacement: passo 1, immagine 1 di 1
    • Remove the fourteen 3.75mm screws with a Phillips #0 Screwdriver as shown.
  2. Toshiba Satellite E45-B4100 Cooling Fan Replacement: passo 2, immagine 1 di 1
    • Gently pull out the battery.
  3. Toshiba Satellite E45-B4100 Cooling Fan Replacement, Cooling Fan: passo 3, immagine 1 di 1
    • Using a spudger, poke the white tabs in by the battery until you hear a click.
  4. Toshiba Satellite E45-B4100 Cooling Fan Replacement: passo 4, immagine 1 di 2 Toshiba Satellite E45-B4100 Cooling Fan Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Pro Tech Toolkit
    $74.95
    • Separate the laptop by sliding a spudger in between the black and silver covers.
    • Be sure to use ESD safe tools, we recommend using the iFixit Pro Tech Toolkit.
  5. Toshiba Satellite E45-B4100 Cooling Fan Replacement: passo 5, immagine 1 di 1
    • Disconnect the Cooling Fan from the Motherboard by gently pulling away on the white tab.
  6. Toshiba Satellite E45-B4100 Cooling Fan Replacement: passo 6, immagine 1 di 1
    • Unscrew the two 3.75mm screws around the Cooling Fan and the copper attachment as shown with the #0 Phillip's Head screwdriver.
  7. Toshiba Satellite E45-B4100 Cooling Fan Replacement: passo 7, immagine 1 di 1
    • Remove the attachment from the Processor by gently rotating and lifting.
Conclusione
USF Tampa, Team 1-4, Leahy Fall 2016 Membro di USF Tampa, Team 1-4, Leahy Fall 2016
USFT-LEAHY-F16S1G4
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 630
