Salta al contenuto principale
Toshiba Satellite Click 2 Pro Hard Drive Replacement
Cosa ti serve
  1. Toshiba Satellite Click 2 Pro Hard Drive  Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite Click 2 Pro Hard Drive  Replacement, Battery: passo 1, immagine 2 di 2
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Push down on the tablet sides until you feel a click, then pull up.
    • This will separate the tablet from the detachable base, make sure to hold down the keyboard for easier detachment.
  2. Toshiba Satellite Click 2 Pro Hard Drive  Replacement: passo 2, immagine 1 di 3 Toshiba Satellite Click 2 Pro Hard Drive  Replacement: passo 2, immagine 2 di 3 Toshiba Satellite Click 2 Pro Hard Drive  Replacement: passo 2, immagine 3 di 3
    • Remove the base of the tablet from the screen using a plastic opening tool.
    • Make sure to separate the base evenly on both sides when removing it from the screen.
  3. Toshiba Satellite Click 2 Pro Hard Drive  Replacement: passo 3, immagine 1 di 2 Toshiba Satellite Click 2 Pro Hard Drive  Replacement: passo 3, immagine 2 di 2
    • Remove the battery power connector using ESD safe tweezers.
  4. Toshiba Satellite Click 2 Pro Hard Drive  Replacement: passo 4, immagine 1 di 2 Toshiba Satellite Click 2 Pro Hard Drive  Replacement: passo 4, immagine 2 di 2
    • Remove the LED ribbon cable using ESD safe tweezers.
    • Remove the SIM card ribbon cable using ESD safe tweezers.
    • Remove the Docking connector ribbon cable using plastic opening tool.
    • The ribbons may be stuck to the battery so make sure to peel off gently to prevent damage.
    • Make sure to flip up the white connector attached to the LED and Sim Card ribbons before removing them .
  5. Toshiba Satellite Click 2 Pro Hard Drive  Replacement: passo 5, immagine 1 di 3 Toshiba Satellite Click 2 Pro Hard Drive  Replacement: passo 5, immagine 2 di 3 Toshiba Satellite Click 2 Pro Hard Drive  Replacement: passo 5, immagine 3 di 3
    • Remove the LCD Display ribbon cable using a plastic opening tool.
    • Remove the I/O ribbon cable using a plastic opening tool.
    • The ribbons may be stuck to the battery so make sure to peel them off gently to prevent damage.
  6. Toshiba Satellite Click 2 Pro Hard Drive  Replacement: passo 6, immagine 1 di 2 Toshiba Satellite Click 2 Pro Hard Drive  Replacement: passo 6, immagine 2 di 2
    • Remove five 3.5mm Phillips J0 screws using a Phillips screw driver.
  7. Toshiba Satellite Click 2 Pro Hard Drive  Replacement: passo 7, immagine 1 di 1
    • Remove the battery from its holding position.
  8. Toshiba Satellite Click 2 Pro Hard Drive  Replacement, Hard Drive: passo 8, immagine 1 di 2 Toshiba Satellite Click 2 Pro Hard Drive  Replacement, Hard Drive: passo 8, immagine 2 di 2
    • Remove the two screws using a J0 Phillips screw driver
  9. Toshiba Satellite Click 2 Pro Hard Drive  Replacement: passo 9, immagine 1 di 1
    • Remove the hard drive
Conclusione
Altre 5 persone hanno completato questa guida.
2 Commenti
Ok, where do i search and order parts please?
Ching Ching - Replica
and plus, i put the laptop model for replacement, doesn't show my laptop model…
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 14
Tutti i Tempi: 3,723
