Salta al contenuto principale
Toshiba Satellite Click 2 L35W-B3204 Hard Drive Replacement
Cosa ti serve
  1. Toshiba Satellite Click 2 L35W-B3204 Hard Drive Replacement, Screen: passo 1, immagine 1 di 3 Toshiba Satellite Click 2 L35W-B3204 Hard Drive Replacement, Screen: passo 1, immagine 2 di 3 Toshiba Satellite Click 2 L35W-B3204 Hard Drive Replacement, Screen: passo 1, immagine 3 di 3
    • Begin by inserting the plastic opening tool into the lip that lies between the screen and the plastic housing and gently prying it open. The best place to begin the screen removal is the bottom left side of the screen.
    • Continue to work your way around the screen with the opening tool until all the clips are undone and the screen is free.
    • Lift screen off of plastic cover to expose the internal components.
  2. Toshiba Satellite Click 2 L35W-B3204 Hard Drive Replacement: passo 2, immagine 1 di 3 Toshiba Satellite Click 2 L35W-B3204 Hard Drive Replacement: passo 2, immagine 2 di 3 Toshiba Satellite Click 2 L35W-B3204 Hard Drive Replacement: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Locate the wide, golden connection on the bottom of the screen. Use the black spudger to peel away the tape holding it in place.
    • Use tweezers to gently remove the plug from the screen.
  3. Toshiba Satellite Click 2 L35W-B3204 Hard Drive Replacement: passo 3, immagine 1 di 3 Toshiba Satellite Click 2 L35W-B3204 Hard Drive Replacement: passo 3, immagine 2 di 3 Toshiba Satellite Click 2 L35W-B3204 Hard Drive Replacement: passo 3, immagine 3 di 3
    • Trace the black ribbon cable that begins on the right of the screen. This cable is connected to the upper part of the motherboard, which is located near the right speaker.
    • Using tweezers, gently grasp the plug on the end of the ribbon cable and remove it from the motherboard.
  4. Toshiba Satellite Click 2 L35W-B3204 Hard Drive Replacement: passo 4, immagine 1 di 1
    • Your screen is now completely detached from the internal components.
  5. Toshiba Satellite Click 2 L35W-B3204 Hard Drive Replacement, Battery: passo 5, immagine 1 di 1
    • Remove the copper shield by removing the four Phillips screws that hold the shield in place.
  6. Toshiba Satellite Click 2 L35W-B3204 Hard Drive Replacement: passo 6, immagine 1 di 1
    • Unplug the battery from the motherboard by pushing the white clip with a metal spudger. You can attempt to use the plastic spudger first, but it may be more difficult.
  7. Toshiba Satellite Click 2 L35W-B3204 Hard Drive Replacement: passo 7, immagine 1 di 2 Toshiba Satellite Click 2 L35W-B3204 Hard Drive Replacement: passo 7, immagine 2 di 2
    • Remove 2 6mm Phillips #0 screws holding the battery in place.
  8. Toshiba Satellite Click 2 L35W-B3204 Hard Drive Replacement: passo 8, immagine 1 di 1
    • Remove the battery by lifting on the left side, while holding the ribbon cable above it out of the way.
  9. Toshiba Satellite Click 2 L35W-B3204 Hard Drive Replacement, Hard Drive: passo 9, immagine 1 di 1
    • Locate the hard drive in the bottom left of the panel.
  10. Toshiba Satellite Click 2 L35W-B3204 Hard Drive Replacement: passo 10, immagine 1 di 1
    • Remove the hard drive using a plastic opening tool.
  11. Toshiba Satellite Click 2 L35W-B3204 Hard Drive Replacement: passo 11, immagine 1 di 1
    • Lift up and unclip the hard drive using the opening tool to pull the plug out.
  12. Toshiba Satellite Click 2 L35W-B3204 Hard Drive Replacement: passo 12, immagine 1 di 2 Toshiba Satellite Click 2 L35W-B3204 Hard Drive Replacement: passo 12, immagine 2 di 2
    • Remove the hard drive from its rubber housing.
Conclusione
To reassemble your device, follow these instructions in order.
Lexi Lannigan
Membro da: 10/17/18
753 Reputazione
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,526
