Salta al contenuto principale
Toshiba Satellite CL-15t-t-B1204X Battery Replacement
Cosa ti serve
  1. Toshiba Satellite CL-15t-t-B1204X Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop over so the bottom of the device is facing upward.
  2. Toshiba Satellite CL-15t-t-B1204X Battery Replacement: passo 2, immagine 1 di 1
    • Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
  3. Toshiba Satellite CL-15t-t-B1204X Battery Replacement: passo 3, immagine 1 di 1
    • Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite CL-15t-t-B1204X Battery Replacement: passo 4, immagine 1 di 1
    • Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
  5. Toshiba Satellite CL-15t-t-B1204X Battery Replacement: passo 5, immagine 1 di 1
    • Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
  6. Toshiba Satellite CL-15t-t-B1204X Battery Replacement: passo 6, immagine 1 di 1
    • Carefully unplug the battery from the device motherboard.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 780
