Salta al contenuto principale
Toshiba Satellite C875-S7304 Motherboard Replacement
Cosa ti serve
  1. Toshiba Satellite C875-S7304 Motherboard Replacement, Battery: passo 1, immagine 1 di 3 Toshiba Satellite C875-S7304 Motherboard Replacement, Battery: passo 1, immagine 2 di 3 Toshiba Satellite C875-S7304 Motherboard Replacement, Battery: passo 1, immagine 3 di 3
    • Power off and unplug the charger from your device.
    • Carefully flip your device upside down laying it onto a flat surface with the battery facing you.
    • The two eject switches are located on the right and left side of the battery compartment.
  2. Toshiba Satellite C875-S7304 Motherboard Replacement: passo 2, immagine 1 di 2 Toshiba Satellite C875-S7304 Motherboard Replacement: passo 2, immagine 2 di 2
    • Slide the right switch further towards the right to lock it into place.
  3. Toshiba Satellite C875-S7304 Motherboard Replacement: passo 3, immagine 1 di 1
    • Slide the switch to the left. Continue to push the switch because unlike the right switch, it will not lock into place.
  4. Toshiba Satellite C875-S7304 Motherboard Replacement: passo 4, immagine 1 di 1
    • Using both hands, continue to push the left switch and grasp onto the center notch located in between the right and left switch.
    • Pull the center notch towards you and you will notice the battery will start to eject.
  5. Toshiba Satellite C875-S7304 Motherboard Replacement: passo 5, immagine 1 di 1
    • Lift the battery out carefully using two hands.
  6. Toshiba Satellite C875-S7304 Motherboard Replacement, Motherboard: passo 6, immagine 1 di 2 Toshiba Satellite C875-S7304 Motherboard Replacement, Motherboard: passo 6, immagine 2 di 2
    • Carefully flip the device back over so that the 'TOSHIBA' logo faces away from you.
    • Open the laptop to display the keyboard.
  7. Toshiba Satellite C875-S7304 Motherboard Replacement: passo 7, immagine 1 di 2 Toshiba Satellite C875-S7304 Motherboard Replacement: passo 7, immagine 2 di 2
    • Using the iFixit opening tool, carefully remove the black plastic bar below the keyboard.
  8. Toshiba Satellite C875-S7304 Motherboard Replacement: passo 8, immagine 1 di 3 Toshiba Satellite C875-S7304 Motherboard Replacement: passo 8, immagine 2 di 3 Toshiba Satellite C875-S7304 Motherboard Replacement: passo 8, immagine 3 di 3
    • Pry the keyboard up and apart from the device.
    • Disconnect the ribbon cable under the keyboard.
  9. Toshiba Satellite C875-S7304 Motherboard Replacement: passo 9, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove all eight of the screws under the keyboard.
  10. Toshiba Satellite C875-S7304 Motherboard Replacement: passo 10, immagine 1 di 2 Toshiba Satellite C875-S7304 Motherboard Replacement: passo 10, immagine 2 di 2
    • Close the device and carefully flip it back over.
  11. Toshiba Satellite C875-S7304 Motherboard Replacement: passo 11, immagine 1 di 3 Toshiba Satellite C875-S7304 Motherboard Replacement: passo 11, immagine 2 di 3 Toshiba Satellite C875-S7304 Motherboard Replacement: passo 11, immagine 3 di 3
    • Use a Phillips #1 to unscrew one 7.0 mm screw from the hard drive/RAM panel and remove panel.
    • Slide the hard drive laterally first and then lift the hard drive up using the clear tab.
    • You cannot remove the screw from the panel. Simply unscrew it until loosened.
  12. Toshiba Satellite C875-S7304 Motherboard Replacement: passo 12, immagine 1 di 1
    • Use a Phillips #1 to remove all 15 of the screws holding the bottom panel intact.
  13. Toshiba Satellite C875-S7304 Motherboard Replacement: passo 13, immagine 1 di 3 Toshiba Satellite C875-S7304 Motherboard Replacement: passo 13, immagine 2 di 3 Toshiba Satellite C875-S7304 Motherboard Replacement: passo 13, immagine 3 di 3
    • Grab the optical drive on either side.
    • Pull the drive out of the device laterally.
  14. Toshiba Satellite C875-S7304 Motherboard Replacement: passo 14, immagine 1 di 3 Toshiba Satellite C875-S7304 Motherboard Replacement: passo 14, immagine 2 di 3 Toshiba Satellite C875-S7304 Motherboard Replacement: passo 14, immagine 3 di 3
    • Gently pry open the entire bottom panel, pulling upward to remove the panel from the device.
  15. Toshiba Satellite C875-S7304 Motherboard Replacement: passo 15, immagine 1 di 3 Toshiba Satellite C875-S7304 Motherboard Replacement: passo 15, immagine 2 di 3 Toshiba Satellite C875-S7304 Motherboard Replacement: passo 15, immagine 3 di 3
    • Remove all wiring from the motherboard and pry it from the device slowly making sure that no ribbons or wires are connected.
  16. Toshiba Satellite C875-S7304 Motherboard Replacement: passo 16, immagine 1 di 1
    • Gently remove the motherboard from inside the device. You are now ready to replace the motherboard.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 48
Tutti i Tempi: 1,648
