Salta al contenuto principale
Toshiba Satellite C875-S7304 Hard Drive Replacement
Cosa ti serve
  1. Toshiba Satellite C875-S7304 Hard Drive Replacement, Battery: passo 1, immagine 1 di 3 Toshiba Satellite C875-S7304 Hard Drive Replacement, Battery: passo 1, immagine 2 di 3 Toshiba Satellite C875-S7304 Hard Drive Replacement, Battery: passo 1, immagine 3 di 3
    • Power off and unplug the charger from your device.
    • Carefully flip your device upside down laying it onto a flat surface with the battery facing you.
    • The two eject switches are located on the right and left side of the battery compartment.
  2. Toshiba Satellite C875-S7304 Hard Drive Replacement: passo 2, immagine 1 di 2 Toshiba Satellite C875-S7304 Hard Drive Replacement: passo 2, immagine 2 di 2
    • Slide the right switch further towards the right to lock it into place.
  3. Toshiba Satellite C875-S7304 Hard Drive Replacement: passo 3, immagine 1 di 1
    • Slide the switch to the left. Continue to push the switch because unlike the right switch, it will not lock into place.
  4. Toshiba Satellite C875-S7304 Hard Drive Replacement: passo 4, immagine 1 di 1
    • Using both hands, continue to push the left switch and grasp onto the center notch located in between the right and left switch.
    • Pull the center notch towards you and you will notice the battery will start to eject.
  5. Toshiba Satellite C875-S7304 Hard Drive Replacement: passo 5, immagine 1 di 1
    • Lift the battery out carefully using two hands.
  6. Toshiba Satellite C875-S7304 Hard Drive Replacement, Hard Drive: passo 6, immagine 1 di 1
    • Use a Phillips #1 to unscrew one 7.0 mm screw from the hard drive/RAM panel.
    • You cannot remove the screw from the panel. Simply unscrew it until loosened.
  7. Toshiba Satellite C875-S7304 Hard Drive Replacement: passo 7, immagine 1 di 3 Toshiba Satellite C875-S7304 Hard Drive Replacement: passo 7, immagine 2 di 3 Toshiba Satellite C875-S7304 Hard Drive Replacement: passo 7, immagine 3 di 3
    • Wedge the plastic opening tool between the back panel and the hard drive/RAM panel near the screw.
    • Lift the end of the opening tool slowly until the hard drive/RAM panel separates on one side.
    • Repeat the steps above on the left side of the hard drive/RAM panel.
    • Pull the cover towards you and up from the device to remove it.
    • Hearing a popping noise while wedging the plastic opening tool is normal.
  8. Toshiba Satellite C875-S7304 Hard Drive Replacement: passo 8, immagine 1 di 3 Toshiba Satellite C875-S7304 Hard Drive Replacement: passo 8, immagine 2 di 3 Toshiba Satellite C875-S7304 Hard Drive Replacement: passo 8, immagine 3 di 3
    • Pull the hard drive laterally to disconnect it from the laptop.
    • Use the clear tab to lift the hard drive out of the laptop.
    • When reassembling, make sure the hard drive lies flat in the laptop before reconnecting it.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,013
