Salta al contenuto principale
Toshiba Satellite C855D-S5303 Hard Drive Replacement
Cosa ti serve
  1. Toshiba Satellite C855D-S5303 Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Using a small Phillip's head screwdriver, unscrew the single 7 mm screw (5 mm head) on the L-shaped panel on the backside of the laptop.
  2. Toshiba Satellite C855D-S5303 Hard Drive Replacement: passo 2, immagine 1 di 2 Toshiba Satellite C855D-S5303 Hard Drive Replacement: passo 2, immagine 2 di 2
    • Once the screw is removed, pry the panel upwards by gripping the groove pictured.
    • Be careful while removing the panel. Don't apply too much force when lifting as you may crack the plastic.
  3. Toshiba Satellite C855D-S5303 Hard Drive Replacement: passo 3, immagine 1 di 3 Toshiba Satellite C855D-S5303 Hard Drive Replacement: passo 3, immagine 2 di 3 Toshiba Satellite C855D-S5303 Hard Drive Replacement: passo 3, immagine 3 di 3
    • Locate the hard drive. It is in a metal casing as pictured.
    • To remove, grab the right side of the piece and slide leftwards.
    • Lift up and out.
Conclusione
Altre 5 persone hanno completato questa guida.
UMass Dartmouth, Team 2-5, Isaacson Fall 2016 Membro di UMass Dartmouth, Team 2-5, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G5
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,708
