Introduzione
This guide will show you how to replace your laptops fan. This process requires only a small Phillips head screwdriver and your hands.
Cosa ti serve
Lay your laptop upside down on a flat surface.
Power off your laptop and unplug the charger.
Using a small Phillip's head screwdriver, unscrew the single 7 mm screw (5 mm head) on the L-shaped panel on the backside of the laptop.
Now that you have your battery and hard drive removed, it's time to begin unscrewing the back panel.
Taking a Phillip's head screwdriver, remove the two 7 mm (5 mm head) screws located around the spot where the hard drive once was.
