Salta al contenuto principale
Toshiba Satellite C855D-S5303 Disc Drive Replacement
Cosa ti serve
  1. Toshiba Satellite C855D-S5303 Disc Drive Replacement, Disc Drive: passo 1, immagine 1 di 3 Toshiba Satellite C855D-S5303 Disc Drive Replacement, Disc Drive: passo 1, immagine 2 di 3 Toshiba Satellite C855D-S5303 Disc Drive Replacement, Disc Drive: passo 1, immagine 3 di 3
    • To begin, locate the middle L-shaped panel on the back of the device. Remove the one 7mm long screw (5mm head) located on that panel.
    • Once the screw is removed, lift the panel by grabbing the indentation by the screw and pulling upwards.
    • Be gentle when lifting, the panel could break if you apply too much force.
  2. Toshiba Satellite C855D-S5303 Disc Drive Replacement: passo 2, immagine 1 di 1
    • Locate the screw to the right of the RAM inside the panel. This screw is 6mm long (5mm head); remove it with a small Phillips head screwdriver.
  3. Toshiba Satellite C855D-S5303 Disc Drive Replacement: passo 3, immagine 1 di 2 Toshiba Satellite C855D-S5303 Disc Drive Replacement: passo 3, immagine 2 di 2
    • Now that the single screw is removed, you should be able to smoothly slide out the disc drive.
    • Do this by grabbing the tray located on the right edge of your device and pulling out.
Conclusione
UMass Dartmouth, Team 2-5, Isaacson Fall 2016 Membro di UMass Dartmouth, Team 2-5, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G5
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 391
