Salta al contenuto principale
Toshiba Satellite C855-S5115 Hard Disk Drive Replacement
Cosa ti serve
  1. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite C855-S5115 Hard Disk Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
  2. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: passo 2, immagine 1 di 1
    • Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
  3. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement, Hard Drive: passo 3, immagine 1 di 1
    • Remove the 7mm Phillips screw located on the back panel of the device using the J1S Phillips head screwdriver.
  4. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: passo 4, immagine 1 di 3 Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: passo 4, immagine 2 di 3 Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: passo 4, immagine 3 di 3
    • Pry the back panel out of the laptop using the spudger tool
  5. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: passo 5, immagine 1 di 2 Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: passo 5, immagine 2 di 2
    • Locate and unscrew the five 3.5mm screws holding the hard drive in place using the J1S Phillips head screwdriver
  6. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: passo 6, immagine 1 di 2 Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: passo 6, immagine 2 di 2
    • Slide the HDD towards the sticker on the left.
  7. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: passo 7, immagine 1 di 2 Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: passo 7, immagine 2 di 2
    • Remove the four 2mm Phillips screws from the HDD tray securing the disk using the J1S Phillips head screwdriver.
    • Remove the hard drive from the tray.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,514
