Salta al contenuto principale
Toshiba Satellite C855-S5115 Cooling Fan Replacement
Cosa ti serve
  1. Toshiba Satellite C855-S5115 Cooling Fan Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite C855-S5115 Cooling Fan Replacement, Battery: passo 1, immagine 2 di 2
    • Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
  2. Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 2, immagine 1 di 1
    • Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
  3. Toshiba Satellite C855-S5115 Cooling Fan Replacement, Cooling Fan: passo 3, immagine 1 di 2 Toshiba Satellite C855-S5115 Cooling Fan Replacement, Cooling Fan: passo 3, immagine 2 di 2
    • Remove the ten 7mm Phillips screws located on the bottom of the laptop using the Phillips #1 screwdriver.
  4. Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 4, immagine 1 di 2 Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 4, immagine 2 di 2
    • Remove the 7mm Phillips screw located on the easy access panel on the bottom of the laptop using a Phillips #1 screwdriver.
  5. Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 5, immagine 1 di 3 Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 5, immagine 2 di 3 Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 5, immagine 3 di 3
    • Insert a plastic opening tool and follow the edges to open the panel.
  6. Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 6, immagine 1 di 1
    • Remove the three 3.5mm Phillips #1 screws indicated in the picture.
  7. Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 7, immagine 1 di 3 Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 7, immagine 2 di 3 Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 7, immagine 3 di 3
    • Remove the 3mm Phillips #1 screw holding the HDD in place, then slide the HDD towards the sticker.
  8. Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 8, immagine 1 di 1
    • Pull the HDD out.
  9. Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 9, immagine 1 di 1
    • Insert a plastic opening tool in between the panel and the main assembly.
  10. Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 10, immagine 1 di 1
    • Work your way around the laptop to remove the base plate.
  11. Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 11, immagine 1 di 1
    • Remove the single 1.5mm Phillips #1 screw located next to the cooling fan.
  12. Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 12, immagine 1 di 1
    • Gently pull out the two pin connector.
  13. Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 13, immagine 1 di 1
    • Remove the CPU fan.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 36
Tutti i Tempi: 1,597
