Salta al contenuto principale
Toshiba Satellite C70D-A RAM Replacement
Cosa ti serve
  1. Toshiba Satellite C70D-A RAM Replacement, RAM: passo 1, immagine 1 di 2 Toshiba Satellite C70D-A RAM Replacement, RAM: passo 1, immagine 2 di 2
    • Power off and unplug the charger from your device.
    • Carefully flip your device upside down, laying it on a flat surface with the battery facing you.
  2. Toshiba Satellite C70D-A RAM Replacement: passo 2, immagine 1 di 2 Toshiba Satellite C70D-A RAM Replacement: passo 2, immagine 2 di 2
    • Slide the two eject switches located on the right and left sides of the battery compartment to release the battery.
    • Gently remove the battery.
  3. Toshiba Satellite C70D-A RAM Replacement: passo 3, immagine 1 di 3 Toshiba Satellite C70D-A RAM Replacement: passo 3, immagine 2 di 3 Toshiba Satellite C70D-A RAM Replacement: passo 3, immagine 3 di 3
    • Use a Phillips #1 screwdriver to loosen the single 7.0 mm screw from the hard drive/RAM panel.
    • You cannot remove the screw from the panel. Simply unscrew it until it is loosened.
    • Pull the cover towards you and up from the device to remove it.
    • If the cover does not come off easily, use an opening tool or spudger to gently pry the cover up.
    • Hearing a snapping noise while removing the hard drive/RAM cover is normal.
  4. Toshiba Satellite C70D-A RAM Replacement: passo 4, immagine 1 di 3 Toshiba Satellite C70D-A RAM Replacement: passo 4, immagine 2 di 3 Toshiba Satellite C70D-A RAM Replacement: passo 4, immagine 3 di 3
    • Push outward on the metal arms to release the RAM from its slot.
    • The RAM will pop up by a few millimeters.
    • Remove it at an angle and not straight up so you don't damage the socket.
    • Carefully slide the RAM stick out of the slot.
    • When reassembling, remember to align the indentation on the RAM with the indentation on its slot.
  5. Toshiba Satellite C70D-A RAM Replacement: passo 5, immagine 1 di 2 Toshiba Satellite C70D-A RAM Replacement: passo 5, immagine 2 di 2
    • After removing the old RAM stick insert the new RAM card.
    • Gently push down on the RAM stick so the metal arms lock around it.
  6. Toshiba Satellite C70D-A RAM Replacement: passo 6, immagine 1 di 3 Toshiba Satellite C70D-A RAM Replacement: passo 6, immagine 2 di 3 Toshiba Satellite C70D-A RAM Replacement: passo 6, immagine 3 di 3
    • Replace the cover and tighten the screw using the Phillips #1 screwdriver.
  7. Toshiba Satellite C70D-A RAM Replacement: passo 7, immagine 1 di 2 Toshiba Satellite C70D-A RAM Replacement: passo 7, immagine 2 di 2
    • Insert the battery back into the laptop.
Conclusione
AYUSH GUPTA
Membro da: 07/02/24
145 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 143
