Salta al contenuto principale
Toshiba Satellite C675-S7106 Wireless Card Replacement
Cosa ti serve
  1. Toshiba Satellite C675-S7106 Wireless Card Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop over, so that the "top" of the laptop is against your working surface.
    • Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
  2. Toshiba Satellite C675-S7106 Wireless Card Replacement: passo 2, immagine 1 di 2 Toshiba Satellite C675-S7106 Wireless Card Replacement: passo 2, immagine 2 di 2
    • On the right side of the battery, move the tab marked 1 to the right, unlocking the battery.
    • On the left side of the battery, hold the tab marked 2 to the left while pulling the battery towards you.
  3. Toshiba Satellite C675-S7106 Wireless Card Replacement, Keyboard: passo 3, immagine 1 di 1
    • Open the laptop with the screen facing you, as if to use it.
  4. Toshiba Satellite C675-S7106 Wireless Card Replacement: passo 4, immagine 1 di 3 Toshiba Satellite C675-S7106 Wireless Card Replacement: passo 4, immagine 2 di 3 Toshiba Satellite C675-S7106 Wireless Card Replacement: passo 4, immagine 3 di 3
    • Starting at the right, pry up part of the plastic bar by using a spudger between the F12 and Insert key.
    • Pull up on the rest of the plastic bar to remove it.
  5. Toshiba Satellite C675-S7106 Wireless Card Replacement: passo 5, immagine 1 di 3 Toshiba Satellite C675-S7106 Wireless Card Replacement: passo 5, immagine 2 di 3 Toshiba Satellite C675-S7106 Wireless Card Replacement: passo 5, immagine 3 di 3
    • Remove the four 2.5mm M2 screws above the keyboard using a PH0 screwdriver.
  6. Toshiba Satellite C675-S7106 Wireless Card Replacement: passo 6, immagine 1 di 3 Toshiba Satellite C675-S7106 Wireless Card Replacement: passo 6, immagine 2 di 3 Toshiba Satellite C675-S7106 Wireless Card Replacement: passo 6, immagine 3 di 3
    • Once screws are removed, lift the keyboard closest to the screen and gently flip it over.
    • Using the spudger, lift up the white ZIF connector to unlatch the ribbon cable, and gently remove the cable.
  7. Toshiba Satellite C675-S7106 Wireless Card Replacement, Wireless Card: passo 7, immagine 1 di 2 Toshiba Satellite C675-S7106 Wireless Card Replacement, Wireless Card: passo 7, immagine 2 di 2
    • Underneath the keyboard, gently disconnect the black and white wires on the right of the wireless adapter using a thin plastic spudger.
    • Be sure to properly re-connect the two wires during assembly, perhaps using the back end of the spudger to ensure that the connection is made.
  8. Toshiba Satellite C675-S7106 Wireless Card Replacement: passo 8, immagine 1 di 1
    • Unscrew the one 3mm screw in the top-left corner of the wireless adapter using a PH0 screwdriver.
  9. Toshiba Satellite C675-S7106 Wireless Card Replacement: passo 9, immagine 1 di 1
    • Lift the card up and to the right to remove it from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 29
Tutti i Tempi: 304
