Introduzione
Sometimes a CMOS battery needs to be replaced or re-seated - in this laptop, that’s a fairly simple and straightforward process. You’ll need a PH0-head screwdriver and a plastic tool to pry the battery from its socket.
Cosa ti serve
Flip the laptop over, so that the "top" of the laptop is against your working surface.
Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
Rotate the laptop so that the battery cavity faces away from you.
Unscrew the single PH0-head screw connecting the center panel to the laptop.
Using a plastic spudger, unclip and remove the panel from the device.
