Salta al contenuto principale
Toshiba Satellite C655D-S5084 Cooling Fan Replacement
Cosa ti serve
  1. Toshiba Satellite C655D-S5084 Cooling Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the device bottom-side up. Make sure the batter compartment is nearest you.
    • Unlock the right side of the battery.
  2. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: passo 2, immagine 1 di 1
    • Unlock the left side of the battery compartment by pushing and holding the button.
    • Remove the battery.
  3. Toshiba Satellite C655D-S5084 Cooling Fan Replacement, Hard Drive: passo 3, immagine 1 di 2 Toshiba Satellite C655D-S5084 Cooling Fan Replacement, Hard Drive: passo 3, immagine 2 di 2
    • Remove the 5.5 mm (F5) screw using the Phillips #0 screwdriver.
    • Remove the plastic cover.
    • The screw may be connected to the cover. If so, loosen it, remove the cover and proceed to the next step.
  4. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: passo 4, immagine 1 di 1
    • Remove the 2.5 mm screw (F3) inside the hard drive casing using the Phillips #1 screwdriver.
    • The screw is located on the small metal tab of the hard drive.
  5. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: passo 5, immagine 1 di 1
    • Slide the large metal tab on the hard drive away from its attachment.
    • With the battery compartment on your left, use your thumb to slide the tab towards you.
  6. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: passo 6, immagine 1 di 1
    • Lift the large metal tab on the hard drive to remove completely.
    • Do not lift until the hard drive is completely free from its base attachment, otherwise you may damage the base.
  7. Toshiba Satellite C655D-S5084 Cooling Fan Replacement, CD/DVD Drive: passo 7, immagine 1 di 1
    • Turn laptop over and remove the 2.5mm "F3" screw using a Phillips #1 screwdriver.
  8. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: passo 8, immagine 1 di 1
    • This step is shown after rotating the device 90 degrees so that the CD drive is closest to you.
    • Wedge a plastic opening tool between the laptop and the CD drive.
    • Gently pull the CD drive out.
  9. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: passo 9, immagine 1 di 1
    • Carefully remove the CD drive completely by pulling out with your hands.
    • The CD drive should come out easily with little force. If there is any resistance double check if 2.5mm "F3" screw is removed completely.
  10. Toshiba Satellite C655D-S5084 Cooling Fan Replacement, Cooling Fan: passo 10, immagine 1 di 2 Toshiba Satellite C655D-S5084 Cooling Fan Replacement, Cooling Fan: passo 10, immagine 2 di 2
    • Remove the 5.5 mm (F5) screw with the Phillips #1 screwdriver.
  11. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: passo 11, immagine 1 di 1
    • Remove the two 6.0 mm (F6) screws with the Phillips #1 screwdriver.
  12. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: passo 12, immagine 1 di 1
    • Remove the fourteen 6.0 mm (F6) screws from the back panel using the Phillips #1 screwdriver.
  13. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: passo 13, immagine 1 di 1
    • Remove the two 6.0 mm golden (F6) screws shown underneath the battery.
  14. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: passo 14, immagine 1 di 1
    • Release the three tabs underneath the battery, using the prying tool.
  15. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: passo 15, immagine 1 di 1
    • Remove the two 2.0 mm screws underneath the CD-Rom drive, using the Phillips #1 screwdriver
    • Release the two tabs using a Phillips #1 screwdriver and the plastic opener.
  16. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: passo 16, immagine 1 di 1
    • Release all internal latches by working the slack around the motherboard.
  17. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: passo 17, immagine 1 di 1
    • Remove the tabs holding the white ribbon in place.
    • A small tool may be required.
  18. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: passo 18, immagine 1 di 1
    • Remove the wide black ribbon in the same manner as the previous step.
    • Release all other catches.
  19. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: passo 19, immagine 1 di 1
    • Detach the white plug by firmly pulling it.
  20. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: passo 20, immagine 1 di 1
    • Detach the other white plug in the same manner as the previous step.
  21. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: passo 21, immagine 1 di 1
    • Remove the three 2.0 mm screws that are holding the fan in place.
  22. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: passo 22, immagine 1 di 1
    • Detach the white plug attached to the cooling fan.
    • Remove the fan and clean.
Conclusione
Altre 9 persone hanno completato questa guida.
Cal Poly, Team 2-20, Maness Spring 2013 Membro di Cal Poly, Team 2-20, Maness Spring 2013
CPSU-MANESS-S13S2G20
4 Membri
15 Guide realizzate
2 Commenti
Excellent description and very precise. I also upgraded to dual Wifi/ Bluetooth (easy to obtain now, lol). Thanks again!
Robert Mackey - Replica
HDD does not actually need to be removed to replace the fan (Steps 3-6) and can stay where it is.
Steps 17-20 can be completed much easier by removing the keyboard first.
Remove the plastic trim across the top of the keyboard.
Remove the 4 screws the trim covers.
Lift the keyboard carefully from the top, there are only tabs holding the bottom of the keyboards which the keyboard slides out from.
This makes it easy to get to the 4 cables shown in steps 17-20 for removal and reinstallation.
I will edit the guide once I've sorted the photos later today.
psycholurch - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 25
Tutti i Tempi: 8,145
