Salta al contenuto principale
Toshiba Satellite C655D-S5084 CD/DVD Drive Replacement
Cosa ti serve
  1. Toshiba Satellite C655D-S5084 CD/DVD Drive Replacement, CD/DVD Drive: passo 1, immagine 1 di 1
    • Turn laptop over and remove the 2.5mm "F3" screw using a Phillips #1 screwdriver.
  2. Toshiba Satellite C655D-S5084 CD/DVD Drive Replacement: passo 2, immagine 1 di 1
    • This step is shown after rotating the device 90 degrees so that the CD drive is closest to you.
    • Wedge a plastic opening tool between the laptop and the CD drive.
    • Gently pull the CD drive out.
  3. Toshiba Satellite C655D-S5084 CD/DVD Drive Replacement: passo 3, immagine 1 di 1
    • Carefully remove the CD drive completely by pulling out with your hands.
    • The CD drive should come out easily with little force. If there is any resistance double check if 2.5mm "F3" screw is removed completely.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 2-20, Maness Spring 2013 Membro di Cal Poly, Team 2-20, Maness Spring 2013
CPSU-MANESS-S13S2G20
4 Membri
15 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 35
Tutti i Tempi: 5,081
