Salta al contenuto principale
Toshiba Satellite C55Dt-A5306 Keyboard Replacement
Cosa ti serve
  1. Toshiba Satellite C55Dt-A5306 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Place fingers on the latches and slide outwards to unlock.
  2. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: passo 2, immagine 1 di 1
    • Remove battery.
  3. Toshiba Satellite C55Dt-A5306 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 2 Toshiba Satellite C55Dt-A5306 Keyboard Replacement, Keyboard: passo 3, immagine 2 di 2
    • After removing the battery, open up your device so that the keyboard is facing you.
  4. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: passo 4, immagine 1 di 2 Toshiba Satellite C55Dt-A5306 Keyboard Replacement: passo 4, immagine 2 di 2
    • Using the spudger, go around the periphery of the keyboard while gently lifting out the keyboard little by little.
  5. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: passo 5, immagine 1 di 1
    • Lift the old keyboard out of the way.
  6. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: passo 6, immagine 1 di 2 Toshiba Satellite C55Dt-A5306 Keyboard Replacement: passo 6, immagine 2 di 2
    • Before pulling out the keyboard, notice that it is connected to the motherboard via a ribbon cable. Gently press out the ribbon cable from its connection site and put the old keyboard aside.
  7. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: passo 7, immagine 1 di 1
    • Locate the keyboard ribbon cable, and the cable retainer keeping it attached to the motherboard.
  8. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: passo 8, immagine 1 di 1
    • Use your nylon spudger to release the retainer by gently lifting the retaining clips on either side.
  9. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: passo 9, immagine 1 di 2 Toshiba Satellite C55Dt-A5306 Keyboard Replacement: passo 9, immagine 2 di 2
    • Once both retaining clips have been lifted up, the ribbon cable should release with a gentle pull.
    • You can now remove the keyboard.
Conclusione
Un commento
mein keyboard war leider noch mit 2 schraubenähnlichen Arretierungen befestigt, und die Laschen an den Seiten ließen sich nur mit Gewalt aufbiegen, so daß das alte Keyboard jetzt im Unterblech ziemlich verbogen ist. C55Dt-A5306
immerich - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 749
