Salta al contenuto principale
Toshiba Satellite C55Dt-A5306 Fan Replacement
Cosa ti serve
  1. Toshiba Satellite C55Dt-A5306  Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Place fingers on the latches and slide outwards to unlock.
  2. Toshiba Satellite C55Dt-A5306  Fan Replacement: passo 2, immagine 1 di 1
    • Remove battery.
  3. Toshiba Satellite C55Dt-A5306  Fan Replacement, Back Cover: passo 3, immagine 1 di 1
    • Using the Phillips Head #0 Screwdriver, remove one 3mm Phillips #0 screw as indicated.
  4. Toshiba Satellite C55Dt-A5306  Fan Replacement: passo 4, immagine 1 di 1
    • Remove hard drive cover. Using the Phillips Head #0 Screwdriver, remove seven 3mm Phillips #0 screws as indicated.
  5. Toshiba Satellite C55Dt-A5306  Fan Replacement: passo 5, immagine 1 di 1
    • Using the Phillips Head #0 Screwdriver, remove twelve 3mm Phillips #0 screw as indicated.
  6. Toshiba Satellite C55Dt-A5306  Fan Replacement: passo 6, immagine 1 di 2 Toshiba Satellite C55Dt-A5306  Fan Replacement: passo 6, immagine 2 di 2
    • Using the plastic spudger, pry the back off along the periphery of the laptop.
  7. Toshiba Satellite C55Dt-A5306  Fan Replacement, Fan/Heatsink Replacement: passo 7, immagine 1 di 1
    • Using the Phillips Head #0 Screwdriver, unscrew four 3mm Phillips #0 screws, on the silver plate under the copper tubing.
  8. Toshiba Satellite C55Dt-A5306  Fan Replacement: passo 8, immagine 1 di 1
    • Using the Phillips Head #0 Screwdriver, remove two 1.5mm Phillips #0 screw holding the fan down.
  9. Toshiba Satellite C55Dt-A5306  Fan Replacement: passo 9, immagine 1 di 1
    • After unscrewing, remove the heatsink from the laptop.
  10. Toshiba Satellite C55Dt-A5306  Fan Replacement: passo 10, immagine 1 di 2 Toshiba Satellite C55Dt-A5306  Fan Replacement: passo 10, immagine 2 di 2
    • Unplug connected wire to remove the fan as indicated. Both the heatsink and fan should be removed before replacement.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 441
