Salta al contenuto principale
Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement
Cosa ti serve
  1. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the laptop upside down so the battery faces upwards.
    • Use a Phillips #1 screwdriver to remove the two, 7 mm screws that secure the battery.
  2. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: passo 2, immagine 1 di 2 Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: passo 2, immagine 2 di 2
    • Place both of your thumbs on the outside edges of the battery and push the battery out to remove it.
    • The battery should slide out with little resistance.
  3. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement, Back Casing: passo 3, immagine 1 di 1
    • Use the screwdriver to remove the thirteen, 7 mm Phillips#1 screws from the bottom of the chassis.
  4. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: passo 4, immagine 1 di 1
    • Insert a spudger at the center and into the crevice between the bottom casing and the keyboard and pry upwards.
    • Gently slide the spudger along the entire perimeter of the device and pry the casing loose to unhook 6 clips.
    • These images show a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
    • Do not be alarmed if you feel a gentle tug or hear a click as you slide your spudger. These sounds are the clips detaching from the casing.
  5. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: passo 5, immagine 1 di 3 Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: passo 5, immagine 2 di 3 Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: passo 5, immagine 3 di 3
    • Using fingers remove the casing.
  6. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement, Wi-Fi Card: passo 6, immagine 1 di 1
    • Unstick the silver tape from the area shown using a non-metallic tool.
  7. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: passo 7, immagine 1 di 1
    • Remove the yellow tape to reveal the plug for the flat strip of wires.
  8. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: passo 8, immagine 1 di 1
    • Locate the gray clips at either side of the plug. Use a non-metallic tool to push the clips away from the plug.
  9. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: passo 9, immagine 1 di 1
    • Unplug the large strip of wires. Lift the large strip of wires out of the way to reveal the Wi-Fi Card.
  10. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: passo 10, immagine 1 di 1
    • Use a non metallic item to pry up on the two metal clips holding the black and white wires. These should pop straight up and will be free from the Wifi Card.
  11. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: passo 11, immagine 1 di 1
    • Use a small Philips screwdriver to remove the screw shown.
  12. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: passo 12, immagine 1 di 1
    • The Wi-Fi Card can now be unplugged from it's port and removed.
Conclusione
Elaine Butler
Membro da: 04/12/22
265 Reputazione
2 Guide realizzate
IUPUI, Team 1-2, Beck Spring 2022 Membro di IUPUI, Team 1-2, Beck Spring 2022
IUPUI-BECK-S22S1G2
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 31
Tutti i Tempi: 697
