1. First, flip the laptop over and use the J1 screwdriver (in the iFixit tool kit) to unscrew the 15 screws indicated in the picture.
    • First, flip the laptop over and use the J1 screwdriver (in the iFixit tool kit) to unscrew the 15 screws indicated in the picture.
    • Make sure to put your screws in a safe place to make sure they do not get lost.
  2. Once you take the screws out, take the battery off; it should slide off easily.
    • Once you take the screws out, take the battery off; it should slide off easily.
  3. Next, move around the edges of the computer with the metal spudger prying off the casing. You should hear clicks as you do this; this is not the casing breaking, it is just popping off.
    • Next, move around the edges of the computer with the metal spudger prying off the casing. You should hear clicks as you do this; this is not the casing breaking, it is just popping off.
  4. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  5. Then, carefully take off the back casing of the laptop and set it aside.
    • Then, carefully take off the back casing of the laptop and set it aside.
  6. This is where the RAM is located that you will be replacing.
    • This is where the RAM is located that you will be replacing.
  7. There are two clips holding the RAM in place.
    • There are two clips holding the RAM in place.
    • You will need to hold both of them back to be able to safely remove the RAM.
    • Use plastic spudgers, as the metal spudgers pictured here are not ESD-safe.
  8. Gently remove the RAM and insert replacement.
    • Gently remove the RAM and insert replacement.
Conclusione
David Amodei
Membro da: 30/11/2017
145 Reputazione
1 Guida realizzata
This guide was done wonderfully. My critique for your group is to be more specific with the direction of how to pull/place the components of the device. Your instructions were simple, yet clear. Great work.
Dan Hartzell - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 240
