Salta al contenuto principale
Toshiba Satellite C55D-B5206 CD Drive Replacement
Cosa ti serve
  1. Toshiba Satellite C55D-B5206 CD Drive Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite C55D-B5206 CD Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the laptop upside down so the battery faces upwards.
    • Use a Phillips #1 screwdriver to remove the two, 7 mm screws that secure the battery.
  2. Toshiba Satellite C55D-B5206 CD Drive Replacement: passo 2, immagine 1 di 2 Toshiba Satellite C55D-B5206 CD Drive Replacement: passo 2, immagine 2 di 2
    • Place both of your thumbs on the outside edges of the battery and push the battery out to remove it.
    • The battery should slide out with little resistance.
  3. Toshiba Satellite C55D-B5206 CD Drive Replacement, Back Casing: passo 3, immagine 1 di 1
    • Use the screwdriver to remove the thirteen, 7 mm Phillips#1 screws from the bottom of the chassis.
  4. Toshiba Satellite C55D-B5206 CD Drive Replacement: passo 4, immagine 1 di 1
    • Insert a spudger at the center and into the crevice between the bottom casing and the keyboard and pry upwards.
    • Gently slide the spudger along the entire perimeter of the device and pry the casing loose to unhook 6 clips.
    • These images show a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
    • Do not be alarmed if you feel a gentle tug or hear a click as you slide your spudger. These sounds are the clips detaching from the casing.
  5. Toshiba Satellite C55D-B5206 CD Drive Replacement: passo 5, immagine 1 di 3 Toshiba Satellite C55D-B5206 CD Drive Replacement: passo 5, immagine 2 di 3 Toshiba Satellite C55D-B5206 CD Drive Replacement: passo 5, immagine 3 di 3
    • Using fingers remove the casing.
  6. Toshiba Satellite C55D-B5206 CD Drive Replacement, CD Drive: passo 6, immagine 1 di 1
    • Remove the 7 mm Philips#1 screw in the back casing removal.
    • Place thumb on the edge of the CD-ROM drive and gently slide the CD-ROM drive towards your palm.
  7. Toshiba Satellite C55D-B5206 CD Drive Replacement: passo 7, immagine 1 di 2 Toshiba Satellite C55D-B5206 CD Drive Replacement: passo 7, immagine 2 di 2
    • Detach the optical drive from its connector and carefully slide it out of the laptop.
    • The drive should slide out and lift away with little resistance. There is no need to slide the drive roughly.
Conclusione
Altre 5 persone hanno completato questa guida.
Tayyaba
Membro da: 09/24/15
527 Reputazione
4 Guide realizzate
CSU Fullerton, Team 2-5, Bruce Fall 2015 Membro di CSU Fullerton, Team 2-5, Bruce Fall 2015
CSUF-BRUCE-F15S2G5
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 18
Tutti i Tempi: 782
