Salta al contenuto principale
Toshiba Satellite C55D-A5304 RAM Replacement
Cosa ti serve
  1. Toshiba Satellite C55D-A5304 RAM Replacement, RAM: passo 1, immagine 1 di 2 Toshiba Satellite C55D-A5304 RAM Replacement, RAM: passo 1, immagine 2 di 2
    • Turn off your laptop and make sure that it is not connected to any power source.
    • Put the laptop upside down so the back panel is facing you.
    • Remove the battery from the back of the computer.
  2. Toshiba Satellite C55D-A5304 RAM Replacement: passo 2, immagine 1 di 3 Toshiba Satellite C55D-A5304 RAM Replacement: passo 2, immagine 2 di 3 Toshiba Satellite C55D-A5304 RAM Replacement: passo 2, immagine 3 di 3
    • Find the backplate on the back of the laptop and unscrew the single, 5mm screw with a Philip Head Screwdriver.
    • Using your finger, go under the ledge of the back plate and take it off to expose the RAM.
  3. Toshiba Satellite C55D-A5304 RAM Replacement: passo 3, immagine 1 di 3 Toshiba Satellite C55D-A5304 RAM Replacement: passo 3, immagine 2 di 3 Toshiba Satellite C55D-A5304 RAM Replacement: passo 3, immagine 3 di 3
    • Once the RAM is exposed, use both hands to unlock the RAM and pull apart the metal pieces holding them in.
    • The card will pop out at an angle and you will need to carefully pull it out. If not using even pressure to remove the card, the RAM will be locked into the slot.
  4. Toshiba Satellite C55D-A5304 RAM Replacement: passo 4, immagine 1 di 1
    • You can insert your new RAM card into the slot very carefully. It will insert at an angle.
    • You can then push down on the flat face of the card and it will lock into place.
Conclusione
AbbyThorng
Membro da: 03/15/23
217 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 121
