Salta al contenuto principale
Toshiba Satellite C55D-A5304 Fan Replacement
Cosa ti serve
  1. Toshiba Satellite C55D-A5304 Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure that the laptop is disconnected from all power sources and turned off.
    • Start with computer upside down with battery slot facing up.
  2. Toshiba Satellite C55D-A5304 Fan Replacement: passo 2, immagine 1 di 1
    • Use the buttons of the sides of the battery to slide inwards and release the battery.
  3. Toshiba Satellite C55D-A5304 Fan Replacement: passo 3, immagine 1 di 1
    • Take the battery out.
  4. Toshiba Satellite C55D-A5304 Fan Replacement, Fan: passo 4, immagine 1 di 1
    • Open the back of the laptop using a pry tool.
  5. Toshiba Satellite C55D-A5304 Fan Replacement: passo 5, immagine 1 di 1
    • Once you see the fan, to make the cleaning process more convenient use a screwdriver to unscrew the 4mm screws on the fan.
    • To the immediate right of the fan the wiring harness is located. Disconnect this also to remove the fan.
  6. Toshiba Satellite C55D-A5304 Fan Replacement: passo 6, immagine 1 di 1
    • Use a microfiber cloth and/or compressed air to clear any dust or clogging.
Conclusione
Emily Verre
Membro da: 03/13/23
211 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 82
