Salta al contenuto principale
Toshiba Satellite C55D-A5201 Keyboard Replacement
Cosa ti serve
  1. Toshiba Satellite C55D-A5201 Keyboard Replacement, Battery: passo 1, immagine 1 di 3 Toshiba Satellite C55D-A5201 Keyboard Replacement, Battery: passo 1, immagine 2 di 3 Toshiba Satellite C55D-A5201 Keyboard Replacement, Battery: passo 1, immagine 3 di 3
    • Close the laptop, and flip it upside down. You want the spine to be furthest away from you.
  2. Toshiba Satellite C55D-A5201 Keyboard Replacement: passo 2, immagine 1 di 1
    • Release the locking mechanism by switching the left slider to the left.
  3. Toshiba Satellite C55D-A5201 Keyboard Replacement: passo 3, immagine 1 di 2 Toshiba Satellite C55D-A5201 Keyboard Replacement: passo 3, immagine 2 di 2
    • Slide the right slider to the right, and simultaneously, pull the battery out at a diagonal angle.
  4. Toshiba Satellite C55D-A5201 Keyboard Replacement, Keyboard: passo 4, immagine 1 di 2 Toshiba Satellite C55D-A5201 Keyboard Replacement, Keyboard: passo 4, immagine 2 di 2
    • Remove the 3mm Phillips #00 screw holding the keyboard in place.
  5. Toshiba Satellite C55D-A5201 Keyboard Replacement: passo 5, immagine 1 di 1
    • Flip over and open the laptop.
  6. Toshiba Satellite C55D-A5201 Keyboard Replacement: passo 6, immagine 1 di 1
    • Slip the plastic opening tool under the "Enter" key on the right corner of the keyboard.
    • Lift the plastic opening tool up until the corner of the keyboard is detached.
    • You will hear a popping sound as each portion of the keyboard becomes detached.
  7. Toshiba Satellite C55D-A5201 Keyboard Replacement: passo 7, immagine 1 di 3 Toshiba Satellite C55D-A5201 Keyboard Replacement: passo 7, immagine 2 di 3 Toshiba Satellite C55D-A5201 Keyboard Replacement: passo 7, immagine 3 di 3
    • Slide the plastic opening tool slowly along the bottom of the keyboard towards the left.
    • Continue up the left side of the keyboard.
  8. Toshiba Satellite C55D-A5201 Keyboard Replacement: passo 8, immagine 1 di 2 Toshiba Satellite C55D-A5201 Keyboard Replacement: passo 8, immagine 2 di 2
    • Lift the keyboard up by grabbing it on both sides.
    • Set the keyboard against the laptop screen.
  9. Toshiba Satellite C55D-A5201 Keyboard Replacement: passo 9, immagine 1 di 3 Toshiba Satellite C55D-A5201 Keyboard Replacement: passo 9, immagine 2 di 3 Toshiba Satellite C55D-A5201 Keyboard Replacement: passo 9, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Using tweezers, push up the two black switches on either side of the ZIF connector.
  10. Toshiba Satellite C55D-A5201 Keyboard Replacement: passo 10, immagine 1 di 2 Toshiba Satellite C55D-A5201 Keyboard Replacement: passo 10, immagine 2 di 2
    • Pull out the ZIF connector to release the keyboard.
    • Lift up the keyboard.
Conclusione
Altre 13 persone hanno completato questa guida.
Kari Byrd
Membro da: 03/24/15
614 Reputazione
1 Guida realizzata
Baylor, Team 6-5, Shaver Spring 2015 Membro di Baylor, Team 6-5, Shaver Spring 2015
BU-SHAVER-S15S6G5
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 5,876
