Salta al contenuto principale
Toshiba Satellite C55D-A5108 Back Cover Replacement
Cosa ti serve
  1. Toshiba Satellite C55D-A5108 Back Cover Replacement, Battery: passo 1, immagine 1 di 1
    • Flip over the device so that the model stickers are facing up.
  2. Toshiba Satellite C55D-A5108 Back Cover Replacement: passo 2, immagine 1 di 1
    • Move the right notch to the unlock position by sliding it to the right.
  3. Toshiba Satellite C55D-A5108 Back Cover Replacement: passo 3, immagine 1 di 1
    • Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
  4. Toshiba Satellite C55D-A5108 Back Cover Replacement, Hard Drive: passo 4, immagine 1 di 1
    • Remove the Phillips #0 screw from the memory cover.
  5. Toshiba Satellite C55D-A5108 Back Cover Replacement: passo 5, immagine 1 di 1
    • Grasp the side of the hard drive opposite the circular battery, and carefully pull out the drive by moving it away from the circular battery.
  6. Toshiba Satellite C55D-A5108 Back Cover Replacement, Back Cover: passo 6, immagine 1 di 3 Toshiba Satellite C55D-A5108 Back Cover Replacement, Back Cover: passo 6, immagine 2 di 3 Toshiba Satellite C55D-A5108 Back Cover Replacement, Back Cover: passo 6, immagine 3 di 3
    • Remove the 16 screws holding the back cover with a Phillips #0 screwdriver.
    • Pry the cover off with an opening tool.
    • Gently remove the cover with your hands and place to the side.
Conclusione
Kristen Gismondi
Membro da: 11/12/14
92.090 Reputazione
241 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.455 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 267
