Salta al contenuto principale
Toshiba Satellite C55D-A5108 Hard Drive Replacement
Cosa ti serve
  1. Toshiba Satellite C55D-A5108  Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Flip over the device so that the model stickers are facing up.
  2. Toshiba Satellite C55D-A5108  Hard Drive Replacement: passo 2, immagine 1 di 1
    • Move the right notch to the unlock position by sliding it to the right.
  3. Toshiba Satellite C55D-A5108  Hard Drive Replacement: passo 3, immagine 1 di 1
    • Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
  4. Toshiba Satellite C55D-A5108  Hard Drive Replacement, Hard Drive: passo 4, immagine 1 di 1
    • Remove the Phillips #0 screw from the memory cover.
  5. Toshiba Satellite C55D-A5108  Hard Drive Replacement: passo 5, immagine 1 di 1
    • Grasp the side of the hard drive opposite the circular battery, and carefully pull out the drive by moving it away from the circular battery.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 298
