Introduzione
The LAN card is important for internet connectivity. If you're having issues connecting to a router, and are sure it's a hardware problem, this is the place to look.
Cosa ti serve
Unscrew the 10 9.0 mm screws holding the back panel on using a Phillips head #1 screwdriver.
Gently remove the ribbon cable from the clip its held in. Peel back the tape holding it in and pull the cable straight out. It is not necessary to unclip the holder.
