Salta al contenuto principale
Toshiba Satellite C55-C5240 Hard Drive Replacement
Cosa ti serve
  1. Toshiba Satellite C55-C5240 Hard Drive Replacement, Battery: passo 1, immagine 1 di 3 Toshiba Satellite C55-C5240 Hard Drive Replacement, Battery: passo 1, immagine 2 di 3 Toshiba Satellite C55-C5240 Hard Drive Replacement, Battery: passo 1, immagine 3 di 3
    • Make sure you turn off the laptop before starting.
    • Remove the two 6.5mm PH1 Phillips screws securing the battery.
  2. Toshiba Satellite C55-C5240 Hard Drive Replacement: passo 2, immagine 1 di 3 Toshiba Satellite C55-C5240 Hard Drive Replacement: passo 2, immagine 2 di 3 Toshiba Satellite C55-C5240 Hard Drive Replacement: passo 2, immagine 3 di 3
    • Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  3. Toshiba Satellite C55-C5240 Hard Drive Replacement, Back cover: passo 3, immagine 1 di 2 Toshiba Satellite C55-C5240 Hard Drive Replacement, Back cover: passo 3, immagine 2 di 2
    • Unscrew the ten 6.5mm PH1 Phillips head screws that hold down the back cover.
  4. Toshiba Satellite C55-C5240 Hard Drive Replacement: passo 4, immagine 1 di 3 Toshiba Satellite C55-C5240 Hard Drive Replacement: passo 4, immagine 2 di 3 Toshiba Satellite C55-C5240 Hard Drive Replacement: passo 4, immagine 3 di 3
    • Using the plastic opening tools, open the back cover and remove it from the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  5. Toshiba Satellite C55-C5240 Hard Drive Replacement, Hard Drive: passo 5, immagine 1 di 3 Toshiba Satellite C55-C5240 Hard Drive Replacement, Hard Drive: passo 5, immagine 2 di 3 Toshiba Satellite C55-C5240 Hard Drive Replacement, Hard Drive: passo 5, immagine 3 di 3
    • The hard drive is on the bottom left side.
    • Remove both releases from the rubber hard drive mount.
  6. Toshiba Satellite C55-C5240 Hard Drive Replacement: passo 6, immagine 1 di 3 Toshiba Satellite C55-C5240 Hard Drive Replacement: passo 6, immagine 2 di 3 Toshiba Satellite C55-C5240 Hard Drive Replacement: passo 6, immagine 3 di 3
    • Lift the hard drive from underneath on the right side.
    • While holding it up, pull it away from its connector so that it disconnects.
  7. Toshiba Satellite C55-C5240 Hard Drive Replacement: passo 7, immagine 1 di 3 Toshiba Satellite C55-C5240 Hard Drive Replacement: passo 7, immagine 2 di 3 Toshiba Satellite C55-C5240 Hard Drive Replacement: passo 7, immagine 3 di 3
    • Peel off the rubber hard drive mount.
Conclusione
Altre 5 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,773
