Salta al contenuto principale
Toshiba Satellite C55-C5240 RAM Replacement
Cosa ti serve
  1. Toshiba Satellite C55-C5240  RAM Replacement, Battery: passo 1, immagine 1 di 3 Toshiba Satellite C55-C5240  RAM Replacement, Battery: passo 1, immagine 2 di 3 Toshiba Satellite C55-C5240  RAM Replacement, Battery: passo 1, immagine 3 di 3
    • Make sure you turn off the laptop before starting.
    • Remove the two 6.5mm PH1 Phillips screws securing the battery.
  2. Toshiba Satellite C55-C5240  RAM Replacement: passo 2, immagine 1 di 3 Toshiba Satellite C55-C5240  RAM Replacement: passo 2, immagine 2 di 3 Toshiba Satellite C55-C5240  RAM Replacement: passo 2, immagine 3 di 3
    • Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  3. Toshiba Satellite C55-C5240  RAM Replacement, Back cover: passo 3, immagine 1 di 2 Toshiba Satellite C55-C5240  RAM Replacement, Back cover: passo 3, immagine 2 di 2
    • Unscrew the ten 6.5mm PH1 Phillips head screws that hold down the back cover.
  4. Toshiba Satellite C55-C5240  RAM Replacement: passo 4, immagine 1 di 3 Toshiba Satellite C55-C5240  RAM Replacement: passo 4, immagine 2 di 3 Toshiba Satellite C55-C5240  RAM Replacement: passo 4, immagine 3 di 3
    • Using the plastic opening tools, open the back cover and remove it from the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  5. Toshiba Satellite C55-C5240  RAM Replacement, RAM: passo 5, immagine 1 di 3 Toshiba Satellite C55-C5240  RAM Replacement, RAM: passo 5, immagine 2 di 3 Toshiba Satellite C55-C5240  RAM Replacement, RAM: passo 5, immagine 3 di 3
    • The RAM is at the upper middle area of the motherboard.
    • Push down on the clips on either side of the RAM stick evenly.
    • It will come loose in an angle once the clips are released.
  6. Toshiba Satellite C55-C5240  RAM Replacement: passo 6, immagine 1 di 1
    • Simply pull out the RAM stick.
    • These steps work for both sticks of RAM.
Conclusione
USF Tampa, Team S1-G5, Nance Spring 2017 Membro di USF Tampa, Team S1-G5, Nance Spring 2017
USFT-NANCE-S17S1G5
3 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,592
