Salta al contenuto principale
Toshiba Satellite C55-B5302 laptop Memory chip (RAM) Replacement
Cosa ti serve
  1. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Battery: passo 1, immagine 2 di 2
    • Flip laptop upside down so you can see the screws.
  2. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: passo 2, immagine 1 di 2 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: passo 2, immagine 2 di 2
    • Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
  3. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: passo 3, immagine 1 di 1
    • Pull the battery from the back of the laptop for removal from the laptop.
  4. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Memory chip (RAM): passo 4, immagine 1 di 3 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Memory chip (RAM): passo 4, immagine 2 di 3 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Memory chip (RAM): passo 4, immagine 3 di 3
    • Remove the remaining thirteen 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
    • Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
    • Expect to hear popping as you pull the back panel off.
  5. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: passo 5, immagine 1 di 3 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: passo 5, immagine 2 di 3 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: passo 5, immagine 3 di 3
    • Push down on the two clips holding the RAM chip in place.
    • Pull the RAM chip up slightly and out away from the connection to remove.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,257
