Salta al contenuto principale
Toshiba Satellite C55-B5302 Screen Bezel Replacement
Cosa ti serve
  1. Toshiba Satellite C55-B5302 Screen Bezel Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite C55-B5302 Screen Bezel Replacement, Battery: passo 1, immagine 2 di 2
    • Flip laptop upside down so you can see the screws.
  2. Toshiba Satellite C55-B5302 Screen Bezel Replacement: passo 2, immagine 1 di 2 Toshiba Satellite C55-B5302 Screen Bezel Replacement: passo 2, immagine 2 di 2
    • Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
  3. Toshiba Satellite C55-B5302 Screen Bezel Replacement: passo 3, immagine 1 di 1
    • Pull the battery from the back of the laptop for removal from the laptop.
  4. Toshiba Satellite C55-B5302 Screen Bezel Replacement, Fan: passo 4, immagine 1 di 3 Toshiba Satellite C55-B5302 Screen Bezel Replacement, Fan: passo 4, immagine 2 di 3 Toshiba Satellite C55-B5302 Screen Bezel Replacement, Fan: passo 4, immagine 3 di 3
    • Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
    • Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
    • Expect to hear popping as you pull the back panel off.
  5. Toshiba Satellite C55-B5302 Screen Bezel Replacement: passo 5, immagine 1 di 1
    • Disconnect the fan wire from the motherboard.
  6. Toshiba Satellite C55-B5302 Screen Bezel Replacement: passo 6, immagine 1 di 3 Toshiba Satellite C55-B5302 Screen Bezel Replacement: passo 6, immagine 2 di 3 Toshiba Satellite C55-B5302 Screen Bezel Replacement: passo 6, immagine 3 di 3
    • Remove the three 3 mm screws with a Phillips #00 screwdriver.
    • Remove the 5 mm screw with a Phillips #0 screwdriver.
  7. Toshiba Satellite C55-B5302 Screen Bezel Replacement: passo 7, immagine 1 di 1
    • You can now lift the fan out of the laptop.
  8. Toshiba Satellite C55-B5302 Screen Bezel Replacement, Screen Bezel: passo 8, immagine 1 di 3 Toshiba Satellite C55-B5302 Screen Bezel Replacement, Screen Bezel: passo 8, immagine 2 di 3 Toshiba Satellite C55-B5302 Screen Bezel Replacement, Screen Bezel: passo 8, immagine 3 di 3
    • After the fan has been removed, lift the hinge so as to get access to the parts below it.
    • Remove the the black colored cable that is now exposed.
  9. Toshiba Satellite C55-B5302 Screen Bezel Replacement: passo 9, immagine 1 di 3 Toshiba Satellite C55-B5302 Screen Bezel Replacement: passo 9, immagine 2 di 3 Toshiba Satellite C55-B5302 Screen Bezel Replacement: passo 9, immagine 3 di 3
    • Remove the 7 mm Phillips #0 screw on the other hinge.
    • Remove the 3.1 mm Phillips #0 screw on the the same hinge.
    • Lift the hinge up and towards you.
  10. Toshiba Satellite C55-B5302 Screen Bezel Replacement: passo 10, immagine 1 di 2 Toshiba Satellite C55-B5302 Screen Bezel Replacement: passo 10, immagine 2 di 2
    • Pull out the wide cable to reveal the components underneath.
  11. Toshiba Satellite C55-B5302 Screen Bezel Replacement: passo 11, immagine 1 di 2 Toshiba Satellite C55-B5302 Screen Bezel Replacement: passo 11, immagine 2 di 2
    • Remove the 3.1 mm Phillips #0 screw holding the chip in place.
    • Pull out the chip.
  12. Toshiba Satellite C55-B5302 Screen Bezel Replacement: passo 12, immagine 1 di 3 Toshiba Satellite C55-B5302 Screen Bezel Replacement: passo 12, immagine 2 di 3 Toshiba Satellite C55-B5302 Screen Bezel Replacement: passo 12, immagine 3 di 3
    • Hold the cable that is to be removed.
    • Use an iFixit opening tool to push down on the white protrusion of cable connector.
    • Now you can pull out the cable.
  13. Toshiba Satellite C55-B5302 Screen Bezel Replacement: passo 13, immagine 1 di 3 Toshiba Satellite C55-B5302 Screen Bezel Replacement: passo 13, immagine 2 di 3 Toshiba Satellite C55-B5302 Screen Bezel Replacement: passo 13, immagine 3 di 3
    • Pivot and lift up the monitor and separate it from the base of the laptop.
  14. Toshiba Satellite C55-B5302 Screen Bezel Replacement: passo 14, immagine 1 di 3 Toshiba Satellite C55-B5302 Screen Bezel Replacement: passo 14, immagine 2 di 3 Toshiba Satellite C55-B5302 Screen Bezel Replacement: passo 14, immagine 3 di 3
    • Use an iFixit opening tool to separate the two halves of the bezel starting at both the plastic hinges.
    • Use the metal spudger to separate the rest of the bezel.
    • Be careful not to scratch the screen with the metal spudger.
    • You may hear some sounds as the clips on the bezel disconnect from the back cover. This is normal.
Conclusione
IUPUI, Team S1-G3, Henning Spring 2019 Membro di IUPUI, Team S1-G3, Henning Spring 2019
IUPUI-HENNING-S19S1G3
4 Membri
6 Guide realizzate
2 Commenti
Sir how will I find screen strip of toshiba c55-b1326
Shahid Iqbal - Replica
Sir how can I find screen strip of toshiba c55-b1326
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 588
