Salta al contenuto principale
Toshiba Satellite C55-B5302 Hard Drive Replacement
Cosa ti serve
  1. Toshiba Satellite C55-B5302 Hard Drive Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite C55-B5302 Hard Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Flip laptop upside down so you can see the screws.
  2. Toshiba Satellite C55-B5302 Hard Drive Replacement: passo 2, immagine 1 di 2 Toshiba Satellite C55-B5302 Hard Drive Replacement: passo 2, immagine 2 di 2
    • Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
  3. Toshiba Satellite C55-B5302 Hard Drive Replacement: passo 3, immagine 1 di 1
    • Pull the battery from the back of the laptop for removal from the laptop.
  4. Toshiba Satellite C55-B5302 Hard Drive Replacement, Hard Drive: passo 4, immagine 1 di 3 Toshiba Satellite C55-B5302 Hard Drive Replacement, Hard Drive: passo 4, immagine 2 di 3 Toshiba Satellite C55-B5302 Hard Drive Replacement, Hard Drive: passo 4, immagine 3 di 3
    • Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
    • Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
    • Expect to hear popping as you pull the back panel off.
  5. Toshiba Satellite C55-B5302 Hard Drive Replacement: passo 5, immagine 1 di 2 Toshiba Satellite C55-B5302 Hard Drive Replacement: passo 5, immagine 2 di 2
    • The hard drive is held in place with a soft, blue rubber retainer. The retainer can be disconnected by pulling up on the two tabs at the left side of the hard drive in these images.
  6. Toshiba Satellite C55-B5302 Hard Drive Replacement: passo 6, immagine 1 di 1
    • Gently pull the hard drive away from the connection to remove it from the laptop.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,187
