Salta al contenuto principale
Toshiba Satellite C55-B5200 Keyboard Replacement
Cosa ti serve
  1. Toshiba Satellite C55-B5200 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop off and remove all sources of power.
    • Flip the laptop over so that way the bottom is facing towards you.
    • Remove the two 6.6mm Phillips #0 screws from the battery.
  2. Toshiba Satellite C55-B5200 Keyboard Replacement: passo 2, immagine 1 di 1
    • Pull the battery out of the laptop.
  3. Toshiba Satellite C55-B5200 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 1
    • Remove the thirteen 6.6mm Phillips #0 screws on the back of the device.
  4. Toshiba Satellite C55-B5200 Keyboard Replacement: passo 4, immagine 1 di 1
    • Use a plastic opening tool to lift and remove the bottom panel.
  5. Toshiba Satellite C55-B5200 Keyboard Replacement: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Remove the six 2.3mm Phillips #0 screws from the motherboard.
    • Use a pair of tweezers to lift up the tab on the ZIF connector and pull out the ribbon cable.
  6. Toshiba Satellite C55-B5200 Keyboard Replacement: passo 6, immagine 1 di 3 Toshiba Satellite C55-B5200 Keyboard Replacement: passo 6, immagine 2 di 3 Toshiba Satellite C55-B5200 Keyboard Replacement: passo 6, immagine 3 di 3
    • Disconnect the wires from the motherboard.
    • Lift and remove the disk drive.
    • Lift and remove the hard drive.
  7. Toshiba Satellite C55-B5200 Keyboard Replacement: passo 7, immagine 1 di 1
    • Lift up the motherboard
    • Use tweezers to carefully peel apart IDE ribbon cables connected from motherboard to keyboard
  8. Toshiba Satellite C55-B5200 Keyboard Replacement: passo 8, immagine 1 di 2 Toshiba Satellite C55-B5200 Keyboard Replacement: passo 8, immagine 2 di 2
    • Use a plastic opening tool to unlatch the keyboard from the device
    • Lift the keyboard off the laptop, careful of the IDE ribbon cable
Conclusione
Altre 2 persone hanno completato questa guida.
Pablo Andrade
Membro da: 02/14/18
1.081 Reputazione
7 Guide realizzate
USF Tampa, Team S3-G1, Nance Spring 2018 Membro di USF Tampa, Team S3-G1, Nance Spring 2018
USFT-NANCE-S18S3G1
4 Membri
22 Guide realizzate
Un commento
gracias por la guía
Mark Puga - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 19
Tutti i Tempi: 4,055
