Salta al contenuto principale
Toshiba Satellite C55-B5200 Hard Disk Drive Replacement
Cosa ti serve
  1. Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop off and remove all sources of power.
    • Flip the laptop over so that way the bottom is facing towards you.
    • Remove the two 6.6mm Phillips #0 screws from the battery.
  2. Toshiba Satellite C55-B5200 Hard Disk Drive Replacement: passo 2, immagine 1 di 1
    • Pull the battery out of the laptop.
  3. Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Hard Disk Drive: passo 3, immagine 1 di 3 Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Hard Disk Drive: passo 3, immagine 2 di 3 Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Hard Disk Drive: passo 3, immagine 3 di 3
    • Remove the two 4.6mm Phillips #0 screws from disk drive.
    • Lift the disk drive and pull out to remove.
Conclusione
Altre 5 persone hanno completato questa guida.
Pablo Andrade
Membro da: 02/14/18
1.081 Reputazione
7 Guide realizzate
USF Tampa, Team S3-G1, Nance Spring 2018 Membro di USF Tampa, Team S3-G1, Nance Spring 2018
USFT-NANCE-S18S3G1
4 Membri
22 Guide realizzate
2 Commenti
Pablo, you didn’t mention that you must remove all the screws to get at the hard drive. What a pain. Other satellites have compartments the c55 that i have you must take every screw out as the back is one piece. Thanks for the instructions.
stevesd619 - Replica
Dónde puedo comprar el disco duro de una laptop toshiba satellite C55
Dulce Martinez - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 19
Tutti i Tempi: 4,680
