Salta al contenuto principale
Toshiba Satellite C55-B5200 Optical Disk Drive Replacement
Cosa ti serve
  1. Toshiba Satellite C55-B5200 Optical Disk Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop off and remove all sources of power.
    • Flip the laptop over so that way the bottom is facing towards you.
    • Remove the two 6.6mm Phillips #0 screws from the battery.
  2. Toshiba Satellite C55-B5200 Optical Disk Drive Replacement: passo 2, immagine 1 di 1
    • Pull the battery out of the laptop.
  3. Toshiba Satellite C55-B5200 Optical Disk Drive Replacement, Optical Disk Drive: passo 3, immagine 1 di 1
    • Make sure device is turned off and unplugged
    • Failure to do so could result in electric shock
    • Use J0 Philips Head Screwdrivers to remove 13, 6.6 mm screws on back of device
  4. Toshiba Satellite C55-B5200 Optical Disk Drive Replacement: passo 4, immagine 1 di 3 Toshiba Satellite C55-B5200 Optical Disk Drive Replacement: passo 4, immagine 2 di 3 Toshiba Satellite C55-B5200 Optical Disk Drive Replacement: passo 4, immagine 3 di 3
    • Remove the remaining two, 6.6 mm screws to remove the battery
    • Use a plastic opening tool to lift and open the back
  5. Toshiba Satellite C55-B5200 Optical Disk Drive Replacement: passo 5, immagine 1 di 1
    • Lift and pull out disk drive
Conclusione
Pablo Andrade
Membro da: 02/14/18
1.081 Reputazione
7 Guide realizzate
USF Tampa, Team S3-G1, Nance Spring 2018 Membro di USF Tampa, Team S3-G1, Nance Spring 2018
USFT-NANCE-S18S3G1
4 Membri
22 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 16
Tutti i Tempi: 721
