Salta al contenuto principale
Toshiba Satellite C55-A5310 Optical Drive Replacement
Cosa ti serve
  1. Toshiba Satellite C55-A5310 Optical Drive Replacement, Battery: passo 1, immagine 1 di 3 Toshiba Satellite C55-A5310 Optical Drive Replacement, Battery: passo 1, immagine 2 di 3 Toshiba Satellite C55-A5310 Optical Drive Replacement, Battery: passo 1, immagine 3 di 3
    • Push the left tab with your left hand.
    • Then push the right tab with your right hand.
    • While your right hand is still pushing, remove the battery with your left hand.
  2. Toshiba Satellite C55-A5310 Optical Drive Replacement, Optical Drive: passo 2, immagine 1 di 2 Toshiba Satellite C55-A5310 Optical Drive Replacement, Optical Drive: passo 2, immagine 2 di 2
    • Remove one screw with a JIS #000 screwdriver.
    • This screw does not come completely out, but you will still be able to get the panel off.
  3. Toshiba Satellite C55-A5310 Optical Drive Replacement: passo 3, immagine 1 di 1
    • Use the plastic opening tool to pry open the back panel. Make sure to loosen all four sides then lift up.
  4. Toshiba Satellite C55-A5310 Optical Drive Replacement: passo 4, immagine 1 di 2 Toshiba Satellite C55-A5310 Optical Drive Replacement: passo 4, immagine 2 di 2
    • Remove a .5mm screw with a JIS #000 screwdriver.
  5. Toshiba Satellite C55-A5310 Optical Drive Replacement: passo 5, immagine 1 di 2 Toshiba Satellite C55-A5310 Optical Drive Replacement: passo 5, immagine 2 di 2
    • Using a plastic opening tool, pry open the disk drive. Once it has loosened it will pull out.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 352
