Salta al contenuto principale
Toshiba Satellite C55-A5310 Fan Replacement
Cosa ti serve
  1. Toshiba Satellite C55-A5310 Fan Replacement, Battery: passo 1, immagine 1 di 3 Toshiba Satellite C55-A5310 Fan Replacement, Battery: passo 1, immagine 2 di 3 Toshiba Satellite C55-A5310 Fan Replacement, Battery: passo 1, immagine 3 di 3
    • Push the left tab with your left hand.
    • Then push the right tab with your right hand.
    • While your right hand is still pushing, remove the battery with your left hand.
  2. Toshiba Satellite C55-A5310 Fan Replacement, Optical Drive: passo 2, immagine 1 di 2 Toshiba Satellite C55-A5310 Fan Replacement, Optical Drive: passo 2, immagine 2 di 2
    • Remove one screw with a JIS #000 screwdriver.
    • This screw does not come completely out, but you will still be able to get the panel off.
  3. Toshiba Satellite C55-A5310 Fan Replacement: passo 3, immagine 1 di 1
    • Use the plastic opening tool to pry open the back panel. Make sure to loosen all four sides then lift up.
  4. Toshiba Satellite C55-A5310 Fan Replacement: passo 4, immagine 1 di 2 Toshiba Satellite C55-A5310 Fan Replacement: passo 4, immagine 2 di 2
    • Remove a .5mm screw with a JIS #000 screwdriver.
  5. Toshiba Satellite C55-A5310 Fan Replacement: passo 5, immagine 1 di 2 Toshiba Satellite C55-A5310 Fan Replacement: passo 5, immagine 2 di 2
    • Using a plastic opening tool, pry open the disk drive. Once it has loosened it will pull out.
  6. Toshiba Satellite C55-A5310 Fan Replacement, Fan: passo 6, immagine 1 di 2 Toshiba Satellite C55-A5310 Fan Replacement, Fan: passo 6, immagine 2 di 2
    • Take a nylon spudger and push the prongs so that it releases the RAM.
  7. Toshiba Satellite C55-A5310 Fan Replacement: passo 7, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Once the RAM has lifted, use tweezers or fingers to pull it out.
  8. Toshiba Satellite C55-A5310 Fan Replacement: passo 8, immagine 1 di 2 Toshiba Satellite C55-A5310 Fan Replacement: passo 8, immagine 2 di 2
    • Remove the single .5mm JIS #000 screw.
  9. Toshiba Satellite C55-A5310 Fan Replacement: passo 9, immagine 1 di 1
    • Use the plastic opening tool to remove the keyboard from the laptop.
  10. Toshiba Satellite C55-A5310 Fan Replacement: passo 10, immagine 1 di 2 Toshiba Satellite C55-A5310 Fan Replacement: passo 10, immagine 2 di 2
    • Once the keyboard is popped out, use a spudger to undo the ribbon or flap that attaches the back of the keyboard to the inside base of the laptop.
  11. Toshiba Satellite C55-A5310 Fan Replacement: passo 11, immagine 1 di 1
    • Remove thirteen JIS #000 11mm screws.
  12. Toshiba Satellite C55-A5310 Fan Replacement: passo 12, immagine 1 di 2 Toshiba Satellite C55-A5310 Fan Replacement: passo 12, immagine 2 di 2
    • Use a nylon spudger tool to lift up on all sides.
    • Once the panel has been loosened it will pop off.
  13. Toshiba Satellite C55-A5310 Fan Replacement: passo 13, immagine 1 di 1
    • Remove five 11mm JIS #000 screws.
  14. Toshiba Satellite C55-A5310 Fan Replacement: passo 14, immagine 1 di 3 Toshiba Satellite C55-A5310 Fan Replacement: passo 14, immagine 2 di 3 Toshiba Satellite C55-A5310 Fan Replacement: passo 14, immagine 3 di 3
    • Remove the four wires with tweezers.
    • Remove wires gently to avoid damaging them.
  15. Toshiba Satellite C55-A5310 Fan Replacement: passo 15, immagine 1 di 1
    • Lift from corresponding sides of the fan and it'll pop right out.
Conclusione
Robin
Membro da: 02/08/18
181 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 602
