Salta al contenuto principale
Toshiba Satellite C55-A5302 Screen Replacement
Cosa ti serve
  1. Toshiba Satellite C55-A5302 Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Power down the laptop and remove all power cords. After this is done, turn the laptop over.
  2. Toshiba Satellite C55-A5302 Screen Replacement: passo 2, immagine 1 di 1
    • Slide the battery latches outwards away from the center of the device.
    • The right latch will slide to the right, and left latch to the left.
  3. Toshiba Satellite C55-A5302 Screen Replacement: passo 3, immagine 1 di 1
    • Lift and remove the battery from the device.
  4. Toshiba Satellite C55-A5302 Screen Replacement, Screen: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Use tweezers to remove the screw covers in the lower corners of the screen.
  5. Toshiba Satellite C55-A5302 Screen Replacement: passo 5, immagine 1 di 1
    • Use the Phillips #1 screwdriver to unscrew the two screws in the lower corners of the screen.
  6. Toshiba Satellite C55-A5302 Screen Replacement: passo 6, immagine 1 di 2 Toshiba Satellite C55-A5302 Screen Replacement: passo 6, immagine 2 di 2
    • Start popping off the cover all the way around the screen until it comes off.
  7. Toshiba Satellite C55-A5302 Screen Replacement: passo 7, immagine 1 di 2 Toshiba Satellite C55-A5302 Screen Replacement: passo 7, immagine 2 di 2
    • Remove the two screws in the top corners with a Phillips #1 screwdriver. The screen will pop forward after removing the two screws.
    • Using the same Phillips #1 screwdriver, remove the three screws on the side of screen frame.
  8. Toshiba Satellite C55-A5302 Screen Replacement: passo 8, immagine 1 di 2 Toshiba Satellite C55-A5302 Screen Replacement: passo 8, immagine 2 di 2
    • On the back of screen, lift up the plastic film and screen connector. Pop out the connector, and gently remove the screen.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 23
Tutti i Tempi: 869
