Salta al contenuto principale
Toshiba Satellite C55-A5302 Keyboard Replacement
Cosa ti serve
  1. Toshiba Satellite C55-A5302 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Power down the laptop and remove all power cords. After this is done, turn the laptop over.
  2. Toshiba Satellite C55-A5302 Keyboard Replacement: passo 2, immagine 1 di 1
    • Slide the battery latches outwards away from the center of the device.
    • The right latch will slide to the right, and left latch to the left.
  3. Toshiba Satellite C55-A5302 Keyboard Replacement: passo 3, immagine 1 di 1
    • Lift and remove the battery from the device.
  4. Toshiba Satellite C55-A5302 Keyboard Replacement, Hard Drive: passo 4, immagine 1 di 1
    • Use the Phillips #1 screwdriver to unscrew the thirteen screws on the back of your device.
  5. Toshiba Satellite C55-A5302 Keyboard Replacement: passo 5, immagine 1 di 1
    • Remove the middle plastic cover to expose the hard drive.
  6. Toshiba Satellite C55-A5302 Keyboard Replacement: passo 6, immagine 1 di 1
    • Using the Phillips #1 screwdriver, remove the two screws holding the hard drive in place.
  7. Toshiba Satellite C55-A5302 Keyboard Replacement: passo 7, immagine 1 di 1
    • Remove the three screws using the Phillips #1 screwdriver.
    • Insert you fingers into the rubber ends and gently pull the hard drive out of the device.
  8. Toshiba Satellite C55-A5302 Keyboard Replacement, Optical Disk Drive: passo 8, immagine 1 di 1
    • Use the Phillips #1 screwdriver to remove the two screws under the hard drive.
  9. Toshiba Satellite C55-A5302 Keyboard Replacement: passo 9, immagine 1 di 1
    • Use a metal spudger and run it along the edges of the computer to take off the plastic back cover. (Starting near a port usually allows more space for the spudger to be inserted)
  10. Toshiba Satellite C55-A5302 Keyboard Replacement: passo 10, immagine 1 di 1
    • Slowly work from one end to the other to lift the back cover off.
  11. Toshiba Satellite C55-A5302 Keyboard Replacement: passo 11, immagine 1 di 2 Toshiba Satellite C55-A5302 Keyboard Replacement: passo 11, immagine 2 di 2
    • Grab hold of the optical drive and elevate it slightly and remove it from the computer.
  12. Toshiba Satellite C55-A5302 Keyboard Replacement, Keyboard: passo 12, immagine 1 di 2 Toshiba Satellite C55-A5302 Keyboard Replacement, Keyboard: passo 12, immagine 2 di 2
    • Using your thumb, apply a light amount of pressure to the underside of the keyboard until it pops out a bit.
  13. Toshiba Satellite C55-A5302 Keyboard Replacement: passo 13, immagine 1 di 1
    • Using the metal spudger, carefully pry up the edges of the keyboard.
  14. Toshiba Satellite C55-A5302 Keyboard Replacement: passo 14, immagine 1 di 1
    • Shift the small tabs on either side of the ribbon outwards to release the end of the ribbon.
    • Gently remove the keyboard from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 463
