Salta al contenuto principale
Introduzione
In this guide, you will learn how to take off the back cover of the Toshiba Satellite C55-A5302 and replace the HDD.
Parti
Nessuna parte specificata.
  1. Power down the laptop and remove all power cords. After this is done, turn the laptop over.
    • Power down the laptop and remove all power cords. After this is done, turn the laptop over.
  2. Slide the battery latches outwards away from the center of the device.
    • Slide the battery latches outwards away from the center of the device.
    • The right latch will slide to the right, and left latch to the left.
  3. Lift and remove the battery from the device.
    • Lift and remove the battery from the device.
  4. Batterie per PC portatili
    Una soluzione semplice per un grande aumento di potenza.
    Acquista ora
    Acquista ora
  5. Use the Phillips #1 screwdriver to unscrew the thirteen screws on the back of your device.
    • Use the Phillips #1 screwdriver to unscrew the thirteen screws on the back of your device.
  6. Remove the middle plastic cover to expose the hard drive.
    • Remove the middle plastic cover to expose the hard drive.
  7. Using the Phillips #1 screwdriver, remove the two screws holding the hard drive in place.
    • Using the Phillips #1 screwdriver, remove the two screws holding the hard drive in place.
  8. Remove the three screws using the Phillips #1 screwdriver.
    • Remove the three screws using the Phillips #1 screwdriver.
    • Insert you fingers into the rubber ends and gently pull the hard drive out of the device.
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 17
Tutti i Tempi: 147
