Salta al contenuto principale
Toshiba Satellite C55-A5302 Hard Drive Replacement
Cosa ti serve
  1. Toshiba Satellite C55-A5302 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Power down the laptop and remove all power cords. After this is done, turn the laptop over.
  2. Toshiba Satellite C55-A5302 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Slide the battery latches outwards away from the center of the device.
    • The right latch will slide to the right, and left latch to the left.
  3. Toshiba Satellite C55-A5302 Hard Drive Replacement: passo 3, immagine 1 di 1
    • Lift and remove the battery from the device.
  4. Toshiba Satellite C55-A5302 Hard Drive Replacement, Hard Drive: passo 4, immagine 1 di 1
    • Use the Phillips #1 screwdriver to unscrew the thirteen screws on the back of your device.
  5. Toshiba Satellite C55-A5302 Hard Drive Replacement: passo 5, immagine 1 di 1
    • Remove the middle plastic cover to expose the hard drive.
  6. Toshiba Satellite C55-A5302 Hard Drive Replacement: passo 6, immagine 1 di 1
    • Using the Phillips #1 screwdriver, remove the two screws holding the hard drive in place.
  7. Toshiba Satellite C55-A5302 Hard Drive Replacement: passo 7, immagine 1 di 1
    • Remove the three screws using the Phillips #1 screwdriver.
    • Insert you fingers into the rubber ends and gently pull the hard drive out of the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 684
