Salta al contenuto principale
Toshiba Satellite C55-A5300 Fan Replacement
Cosa ti serve
  1. Toshiba Satellite C55-A5300 Fan Replacement, Battery: passo 1, immagine 1 di 3 Toshiba Satellite C55-A5300 Fan Replacement, Battery: passo 1, immagine 2 di 3 Toshiba Satellite C55-A5300 Fan Replacement, Battery: passo 1, immagine 3 di 3
    • With the Laptop off, turn it over.
    • The battery is located next to the screen hinges.
    • Move the locking tab located directly above the battery on the right side, all the way to the left. It will stay in place by itself.
  2. Toshiba Satellite C55-A5300 Fan Replacement: passo 2, immagine 1 di 3 Toshiba Satellite C55-A5300 Fan Replacement: passo 2, immagine 2 di 3 Toshiba Satellite C55-A5300 Fan Replacement: passo 2, immagine 3 di 3
    • Slide the tab identical to the first one on the right side above the battery pack to the right. This tab is spring loaded, so be sure to hold it.
    • Insert your tool or your fingernail into the notch just above the center of the battery pack, and lift the battery pack out of the device.
  3. Toshiba Satellite C55-A5300 Fan Replacement, Hard Drive: passo 3, immagine 1 di 1
    • Unscrew the screw on the back panel of the laptop covering the hard drive.
  4. Toshiba Satellite C55-A5300 Fan Replacement: passo 4, immagine 1 di 1
    • Use the plastic opening tools to remove the panel.
  5. Toshiba Satellite C55-A5300 Fan Replacement: passo 5, immagine 1 di 1
    • Remove the screw next to the hard drive using the PH1 screwdriver.
  6. Toshiba Satellite C55-A5300 Fan Replacement: passo 6, immagine 1 di 1
    • Pull the silver tab connected to the hard drive up to take it out.
  7. Toshiba Satellite C55-A5300 Fan Replacement, Fan: passo 7, immagine 1 di 1
    • Using the PH1 screwdriver, remove the remaining screws from the back casing of the laptop.
  8. Toshiba Satellite C55-A5300 Fan Replacement: passo 8, immagine 1 di 1
    • Use a nylon spudger or plastic opening tool to carefully wedge the casing apart and remove the back plate of the laptop.
  9. Toshiba Satellite C55-A5300 Fan Replacement: passo 9, immagine 1 di 2 Toshiba Satellite C55-A5300 Fan Replacement: passo 9, immagine 2 di 2
    • Remove the 2 screws holding the fan in place.
  10. Toshiba Satellite C55-A5300 Fan Replacement: passo 10, immagine 1 di 2 Toshiba Satellite C55-A5300 Fan Replacement: passo 10, immagine 2 di 2
    • Detach the multi-colored wire connecting the fan to the motherboard and pull the fan out.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 424
