Salta al contenuto principale
Toshiba Satellite C55-A5300 Battery Replacement
Cosa ti serve
  1. Toshiba Satellite C55-A5300 Battery Replacement, Battery: passo 1, immagine 1 di 3 Toshiba Satellite C55-A5300 Battery Replacement, Battery: passo 1, immagine 2 di 3 Toshiba Satellite C55-A5300 Battery Replacement, Battery: passo 1, immagine 3 di 3
    • With the Laptop off, turn it over.
    • The battery is located next to the screen hinges.
    • Move the locking tab located directly above the battery on the right side, all the way to the left. It will stay in place by itself.
  2. Toshiba Satellite C55-A5300 Battery Replacement: passo 2, immagine 1 di 3 Toshiba Satellite C55-A5300 Battery Replacement: passo 2, immagine 2 di 3 Toshiba Satellite C55-A5300 Battery Replacement: passo 2, immagine 3 di 3
    • Slide the tab identical to the first one on the right side above the battery pack to the right. This tab is spring loaded, so be sure to hold it.
    • Insert your tool or your fingernail into the notch just above the center of the battery pack, and lift the battery pack out of the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 466
