Salta al contenuto principale
Toshiba Satellite C55-A5286 Optical Drive Replacement
Cosa ti serve
  1. Toshiba Satellite C55-A5286 Optical Drive Replacement, Optical Drive: passo 1, immagine 1 di 1
    • Unplug the AC adapter and all other auxiliary components from the laptop
  2. Toshiba Satellite C55-A5286 Optical Drive Replacement: passo 2, immagine 1 di 2 Toshiba Satellite C55-A5286 Optical Drive Replacement: passo 2, immagine 2 di 2
    • Unscrew the only screw (5 mm) that is holding on the removable back panel and remove the back panel.
  3. Toshiba Satellite C55-A5286 Optical Drive Replacement: passo 3, immagine 1 di 1
    • Remove the two 5-mm screws near the disk drive on the back panel. These two screws are above and below the manufacturer’s sticker.
  4. Toshiba Satellite C55-A5286 Optical Drive Replacement: passo 4, immagine 1 di 1
    • Under the back panel, remove the 4-mm screw holding the disk drive in place.
  5. Toshiba Satellite C55-A5286 Optical Drive Replacement: passo 5, immagine 1 di 2 Toshiba Satellite C55-A5286 Optical Drive Replacement: passo 5, immagine 2 di 2
    • Carefully slide the optical drive out of its place in the laptop.
Conclusione
Altre 2 persone hanno completato questa guida.
IUPUI, Team S1-G5, Hovde Fall 2018 Membro di IUPUI, Team S1-G5, Hovde Fall 2018
IUPUI-HOVDE-F18S1G5
2 Membri
9 Guide realizzate
Un commento
Not a medium effort at all - very easy.
…although, I did have to use an iFixt It needle-nose tweezer to pull the middle 5mm screw out after it was unscrewed - it would not fall out nor did it cling to the screwdriver.
William Totman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 298
