Salta al contenuto principale
Toshiba Satellite C55-A5140 Keyboard Replacement
Cosa ti serve
  1. Toshiba Satellite C55-A5140 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Make sure that the device is unplugged, completely off, and that the device is not warm to the touch.
    • Working from left to right, use plastic opening tool to lift keyboard up and out of recessed holding tray.
    • Continue to pry around the entire keyboard until it is loose enough to easily slide your fingers underneath the corners of the keyboard.
    • Once existing keyboard is removed, it can no longer be reinstalled. Be sure to have new keyboard available for installation.
    • Keyboard will make a snapping sound as it is freed from tray.
  2. Toshiba Satellite C55-A5140 Keyboard Replacement: passo 2, immagine 1 di 2 Toshiba Satellite C55-A5140 Keyboard Replacement: passo 2, immagine 2 di 2
    • Using hands, gently pull keyboard out of device.
Conclusione
To reassemble your device, use tabs on new keyboard to snap into keyboard tray
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 20
Tutti i Tempi: 568
