Salta al contenuto principale
Toshiba Satellite C55-A5100 Optical Drive Replacement
Cosa ti serve
  1. Toshiba Satellite C55-A5100 Optical Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 Optical Drive Replacement: passo 2, immagine 1 di 1
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 Optical Drive Replacement, Optical Drive: passo 3, immagine 1 di 3 Toshiba Satellite C55-A5100 Optical Drive Replacement, Optical Drive: passo 3, immagine 2 di 3 Toshiba Satellite C55-A5100 Optical Drive Replacement, Optical Drive: passo 3, immagine 3 di 3
    • Place laptop with the bottom of it facing up.
    • Remove the single 6mm Phillips #1 screw keeping the laptop panels in place.
  4. Toshiba Satellite C55-A5100 Optical Drive Replacement: passo 4, immagine 1 di 1
    • Remove the 4mm Phillips #1 screw on the side of the now exposed area.
  5. Toshiba Satellite C55-A5100 Optical Drive Replacement: passo 5, immagine 1 di 1
    • Remove the disc drive from the device.
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
Any idea of how tall the drive is? Is it 12.7mm or 9.5mm tall?
Luis Alejandro Araúz - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 331
