Salta al contenuto principale
Toshiba Satellite C55-A5100 Keyboard Replacement
Cosa ti serve
  1. Toshiba Satellite C55-A5100 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 Keyboard Replacement: passo 2, immagine 1 di 1
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 1
    • On the back of the laptop, remove the 6mm Phillips #1 screw. This screw is attached to the keyboard.
  4. Toshiba Satellite C55-A5100 Keyboard Replacement: passo 4, immagine 1 di 1
    • Looking at the keyboard, locate the eight clips that hold it in place.
  5. Toshiba Satellite C55-A5100 Keyboard Replacement: passo 5, immagine 1 di 2 Toshiba Satellite C55-A5100 Keyboard Replacement: passo 5, immagine 2 di 2
    • Use the plastic opening tool to slide the clips back, releasing the keyboard.
    • As you release the clips, use the plastic opening tool to lift keyboard above the clips.
  6. Toshiba Satellite C55-A5100 Keyboard Replacement: passo 6, immagine 1 di 1
    • Once the keyboard is released from the clips you should be able to lift it up, exposing the wire connecting it to the laptop.
    • The keyboard will slide out of the clips on the top.
  7. Toshiba Satellite C55-A5100 Keyboard Replacement: passo 7, immagine 1 di 1
    • Using your fingers, slowly pull the wire out of its connection.
    • The keyboard is now disconnected.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,016
