Salta al contenuto principale
Toshiba Satellite C55-A5100 Hard Drive Replacement
Cosa ti serve
  1. Toshiba Satellite C55-A5100 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 3 Toshiba Satellite C55-A5100 Hard Drive Replacement, Hard Drive: passo 3, immagine 2 di 3 Toshiba Satellite C55-A5100 Hard Drive Replacement, Hard Drive: passo 3, immagine 3 di 3
    • Place the laptop with the bottom facing up.
    • Remove the single 6mm Phillips #1 screw keeping the laptop panels in place.
  4. Toshiba Satellite C55-A5100 Hard Drive Replacement: passo 4, immagine 1 di 1
    • Using the Phillips #1 screwdriver, remove the 8mm screw that is holding the hard drive in place.
  5. Toshiba Satellite C55-A5100 Hard Drive Replacement: passo 5, immagine 1 di 2 Toshiba Satellite C55-A5100 Hard Drive Replacement: passo 5, immagine 2 di 2
    • Use your finger to lift the hard drive up.
    • Pull out the hard drive to the right.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 24
Tutti i Tempi: 918
